when i click on the file browser icon to access the files on my pc everything is fine. i double click on the file (mpeg in this case) and DVDlab pro breaks it down into video and audio just fine.
MY question is ...... IS THERE ANY WAY TO HAVE THE AUDIO AND VIDEO FILES THAT DVDLab Pro CREATES GO INTO A SPECIFIED FOLDER???
in other words, if i have a folder named "movie" and i have a mpeg in the folder named "videohelpdrama" ... when i open the mpeg file in dvdlab pro ... it will break it down into an audio and video file (say videohelpdrama.mpg and videohelpdrama.mp3 for example)
but it puts those two new files in the same folder as the original mpeg they were created from. is there any way to specify that i want those two new files in a separate folder??
In the 'Options' tab under 'Project/Project Properties' there are radio buttons that control the demuxing, including the folder destination.
Just select 'always ask' -
Go to Project --> Project Properties -->Options. You should see an entry called Demux Directory with a dot in the box for Same as Input. Change that to Always Ask.
Drat...beat to the punch by one minute.
thanks man i really appriciate it!!
i was going thru some of the options but i guess i didnt look hard enuff.
i was already leaning toward coming on here to ask anyway thats probably why i didnt do a thorough search for it
thanks again!!!
Vegas Pro quick question
By ingeborgdot in forum EditingReplies: 7Last Post: 4th Oct 2010, 15:18 -
Quick DVD LAB Pro question
By sterankin in forum Authoring (DVD)Replies: 5Last Post: 12th Aug 2010, 05:13 -
HD PVR vs BMI Pro - possibly quick question
By 80r in forum Capturing and VCRReplies: 2Last Post: 25th Mar 2010, 08:13 -
Motion Menus in DVDLab Pro question
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 1Last Post: 8th Mar 2009, 16:47 -
Quick ATI Wonder Pro question compatibility
By bradyfan123 in forum Capturing and VCRReplies: 2Last Post: 25th Feb 2008, 16:35
