    Apr 2005
    Hi, I have Vegas Movie Studio Platinium 9 and I like it alot
    I have import HDV file from my camera and Xvid and that.
    But I have some m2ts that I can't import
    I guess that I need some kind of codec for AVC.
    I have codec for AC-3 (Have Nero codec) but if that any free good codec that make me read m2ts files
    I have try with "Haali Media Splitter" and "ffshow" but I can't import the file anyway
    General
    Complete name                    : D:\testing.m2ts
    Format                           : BDAV
    Format/Info                      : Blu-ray Video
    File size                        : 90.4 MiB
    Duration                         : 24s 660ms
    Overall bit rate                 : 30.7 Mbps
    Maximum Overall bit rate         : 48.0 Mbps
    Video
    Menu ID                          : 1 (0x1)
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format profile                   : High@L4.1
    Format settings, CABAC           : Yes
    Format settings, ReFrames        : 4 frames
    Duration                         : 23s 957ms
    Width                            : 1 920 pixels
    Height                           : 1 080 pixels
    Display aspect ratio             : 16:9
    Frame rate                       : 29.970 fps
    Standard                         : NTSC
    Resolution                       : 8 bits
    Colorimetry                      : 4:2:0
    Scan type                        : MBAFF
    Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics         : BT.709-5, BT.1361
    Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio
    Menu ID                          : 1 (0x1)
    Format                           : AC-3
    Format/Info                      : Audio Coding 3
    Format profile                   : TrueHD / Core
    Muxing mode                      : Stream extension
    Duration                         : 24s 22ms
    Bit rate mode                    : Variable / Constant
    Bit rate                         : Variable / 640 Kbps
    Maximum bit rate                 : 6 564 Kbps / 640 Kbps
    Channel(s)                       : 8 channels / 6 channels
    Channel positions                : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
    Sampling rate                    : 48.0 KHz
  2. The audio won't be supported even by the vegas pro version (truehd)
    You can dump the AC3 core in tsmuxer or convert it with eac3to to something like mono wavs for import
    Re-wrapping should allow you to import as well
    Summary : load the file into tsmuxer, highlight the audio track, checkmark "downconvert true-hd to ac3", checkmark m2ts muxing, press start muxing
  3. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Where did you get that file? I'm guessing Hauppage PVR?
    Update: Forget it, I just figured it out.
  4. Originally Posted by budwzr View Post
    can't be; bitrate is too high for Hauppage, and audio is TrueHD
    it's likely a section from blu-ray
  5. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Right, I just noticed that. It's AVCi.
