Hi
I have some m2ts file that I like to convert to DVD but I have problem to convert them
I have try multiAVCHD and it work great if the m2ts file is 2.0 sound but if the file have 5.1 or 7.1 it get error and I can't do anything about it.
That is so that I like to convert m2ts 5.1/7.1 to DVD movie that have 5.1 or 7.1
I haven't had that problem with multiavchd.
What type of sound is it? Dolby truehd or dts hd? Try eac3to to convert to a standard definition audio format - 48khz and 448kpbs for dolby digital and 48khz 1510kpbs for dts - but you'll need a dts encoder for dts and they are not free - dolby is included with eac3to and should work just fine for a dvd.
Also if the problem persists try avstodvd. It can handle high def files and can create standard definition dvds.
Edit - also standard dvds only handle up to 6.1 audio not 7.1 - don't know if that is a factor for you but I think it should still retain 5.1 from the 7.1.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I have look at eac3to but I'm not sure what to pick
I can create a ac3 file and mkv file but what more do I need to create a DVD as good quality as possible and with 5.1 sound?
Going to look at AVStoDVD
Info of the file is this
Code:General ID : 0 Complete name : D:\testing.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 90.4 MiB Duration : 24s 660ms Overall bit rate : 30.7 Mbps Maximum Overall bit rate : 48.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Duration : 23s 957ms Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Standard : NTSC Resolution : 8 bits Colorimetry : 4:2:0 Scan type : MBAFF Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Format profile : TrueHD / Core Muxing mode : Stream extension Duration : 24s 22ms Bit rate mode : Variable / Constant Bit rate : Variable / 640 Kbps Maximum bit rate : 6 564 Kbps / 640 Kbps Channel(s) : 8 channels / 6 channels Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz
If you want it to be a playable dvd in a regular dvd player it must be mpeg2 video with ac3 or dts sound at 48khz with 5.1 or 6.1 audio max (no 7.1).Originally Posted by cazz
I still don't know the problem multiavchd has with your input file. But it should be able to make a sd dvd - there is an output option for sd dvd next to the hd dvd button when you begin encoding.
But please try avstodvd. It will take your m2ts as an input file. You can create a dvd for a dual layer or single layer dvdr. Dual layer will let you increase the bitrate and maintain more quality.
Remember sd dvd is 720x480 ntsc and 720x576 for pal. So even at max bitrate for dvd it won't look as good as the high def original. But it will still look good just not as awesome as the high def file.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
how to convert a m2ts to dvd
By splinter3217 in forum Video ConversionReplies: 19Last Post: 18th May 2011, 19:04 -
Convert M2TS file to dvd
By dude905 in forum Video ConversionReplies: 9Last Post: 16th Apr 2011, 06:13 -
Convert DVD to M2TS with subs & chapters for streaming
By BS_done_right in forum Video ConversionReplies: 1Last Post: 14th Mar 2011, 20:43 -
how do you convert m2ts
By Onceler2 in forum Video ConversionReplies: 9Last Post: 8th Dec 2009, 06:12
