  1. Last night, my friend gave me a recording of an HD video he took and I tried to convert it into a lesser version of mp4 or 3gs in order to view it on my phone. I used the program called SUPER. In the past, I have had no problems with it, but for some reason, it keeps giving me an error. I've tried 3 different videos from the same video camera and I can't convert any of them. I don't know what the problem is. Is the SUPER Analysis box suppose to give me a heads up on what's wrong (i.e. highlight erroneous parts in red)? Thank you in advance for your answers!
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Try WinFF
  3. hmmm... When I run it to convert, the cmd prompt-like window just disappears.
    Edit: Should I post the properties of the video?
  4. yes, post the properties
    you can use mediainfo (view=>text) and copy & paste it here
    do the videos play in a media player correctly ?
  5. Ok, here's the info:
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 2.98 GiB
    Duration : 2h 58mn
    Overall bit rate : 2 389 Kbps
    Encoded date : UTC 2010-07-07 20:14:56
    Tagged date : UTC 2010-07-07 20:14:56
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 8 frames
    Codec ID : avc1
    Duration : 2h 58mn
    Bit rate mode : Variable
    Bit rate : 1 991 Kbps
    Maximum bit rate : 40.0 Mbps
    Width : 1 280 pixels
    Height : 528 pixels
    Display aspect ratio : 2.40:1
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.123
    Stream size : 2.48 GiB (83%)
    Writing library : x264 core 100 r1659 57b2e56
    Encoding settings : cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:1.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-4 / threads=6 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=5 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=24 / keyint_min=2 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=2pass / mbtree=1 / bitrate=1991 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=vbr
    Encoded date : UTC 2010-07-07 06:24:06
    Tagged date : UTC 2010-07-07 20:17:10
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 40
    Duration : 2h 58mn
    Bit rate : 395 Kbps
    Maximum bit rate : 456 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Stream size : 504 MiB (17%)
    Language : English
    Encoded date : UTC 2010-07-07 20:16:45
  6. hmmm I tried xmediarecode, but the encode button is always greyed out.... Also, the video does work. I even viewed it through the xmediarecode preview tab. This is really weird huh?
