I can set my Samsung camcorder to either standard or widescreen mode. I have it set to widescreen.
But even though it is in widescreen mode, my camera still shoots at 720 x 480 and the video files are with the extension MP4.
My intention is to save my video files in DVD using the correct size in order to mantain the original quality.
If I use Nero or another similar program to work with the MP4 files directly the information of the video files that the programs detects is 720x480 in 4:3 and not 16:9 as I supposed, so finally I obtain a video with black vertical colums at left and right when I played it in a 16:9 TV.
Another option that I have is using the Intelli Studio software provided with the camcoder that shows me different options to save the files in a format like WMV or H.264.
The options are 16:9 (1920x1080), (960x540) or less... and in 4:3 (800x600), (640:480) or less.
I saved the file in 16:9 (960x540) and after that, when I open the file using Nero save the file in 16:9 with 720x480 and It seems to be ok in the TV.
I wolud like to know if in the whole process I am loosing quality as I go from 720x480 to 960x540 and finally 720x480 again or If I need to use a different process.
what model is your camcorder ?
If you are shooting HD , then yes, you are unneccesarily losing quality with the intermediate step
If it is HD camcorder, then you will lose quality because DVD is standard definition. You need a blu-ray player or PS3 to be able to play HD content and original qualityMy intention is to save my video files in DVD using the correct size in order to mantain the original quality. -
and DVD is MPeg2 with resolution 720x480 for 4:3 or 16:9.
https://www.videohelp.com/dvdRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
DVD resolution is 720 x 480 ??
By siratfus in forum Video ConversionReplies: 6Last Post: 3rd Mar 2013, 10:47 -
SD 720 x 480 - how do I upload to youtube so it fills the frame?
By Bansaw in forum Newbie / General discussionsReplies: 1Last Post: 25th Feb 2012, 02:50 -
How to convert .vob file 702x480 to 720 x 480
By illpeeonu in forum Video ConversionReplies: 2Last Post: 23rd Jan 2009, 10:39 -
Newbie question about 720 x 480 dvd resolution
By siratfus in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2008, 18:30 -
avi (640*480) to dvd (720*480) without black bars....how?
By Mauserman in forum ffmpegX general discussionReplies: 8Last Post: 10th Sep 2007, 13:25
