Hi,
I have been playing Scrabble CE for quite a while.
All of a sudden, it would not load - I used to be able to uninstall and reinstall and that would solve the problem.
Yesterday, I had a different problem and was told to do a system refresh using -MSINFO32.
That solved the problem and by coincidence the game started running.
I stopped the game and restarted it 3 times with no problem.
Now I am back to square one. Will not load.
After uninstalling and reinstalling, the message says "restart to finish installation." - nothing happens.
By the way, I also play Scrabble Complete and that loads perfectly.
I have also reinstalled my graphics card Radon Express 200.
Any ideas as to what is blocking it?
Thank you.
Paul
1090T Computer Won't Load DVD Players
By wulf109 in forum Software PlayingReplies: 7Last Post: 23rd Apr 2012, 13:25 -
convertx todvd won't load
By xbill in forum Newbie / General discussionsReplies: 5Last Post: 27th Sep 2010, 15:22 -
Windows XP won't load
By Tom Saurus in forum ComputerReplies: 21Last Post: 12th Jun 2010, 10:36 -
Application won't load for all users
By mattman1968 in forum ComputerReplies: 9Last Post: 9th Nov 2007, 10:22 -
Program won't load?
By darrenp76 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Sep 2007, 03:36
