Does ImgBurn not burn text files? Notepad, ect...
I always add a file to the VIDEO_TS folder called Info which is just a copy and paste from AnyDVD.
For example:
Summary for drive E: (AnyDVD 6.7.1.0)
Drive (Hardware) Region: 1
Media is a DVD.
Booktype: dvd-rom (version 1), Layers: 2 (opposite)
Size of first Layer: 2076928 sectors (4056 MBytes)
Total size: 4125984 sectors (8058 MBytes)
Video DVD (or CD) label: TINKERBELL_GFR
Media is CSS protected!
Media is locked to region(s): 1 4!
Video Standard: NTSC
Found & removed structural copy protection!
Found & removed invalid cell pieces!
Found & removed bogus title set(s)!
Found & removed invalid VOBUs!
RCE protection not found.
UDF filesystem patched!
Autorun not found on Video DVD.
Removed CSS copy protection!
Found & removed 7 potential bad sector protections!
Emulating RPC-2 drive with region 1!
CloneDVD 2.9.2.8
Just so I know what protections are removed and so forth. Is there a way to add that file to the burn disc? Evidently ImgBurn doesn't include that even though it's in the folder.
IMGBURN will burn folders in addition to the VIDEO_TS folder as long as there is available space on the dvd.
Create a folder seperate from the VIDEO_TS folder (EXTRAS or NOTES for example) and add your text file, along with any other files you woud like on the dvd. In IMGBURN, after you select your VIDEO_TS folder, select your additional folder and it will be included in the burn provided there is enough free space to include your additional folder. -
Oh ok, see I just added the VIDEO_TS and thought it would add the notepad file. Didn't even think about adding an additional folder just for the text file.
By default, it filters subfolders and non ifo/bup/vob files from the VIDEO_TS folder.
You could just add your txt file to the root of the disc, there's no need for an extra folder if you don't want it. -
The root is the root, it's the erm... let's call it a folder... that the VIDEO_TS folder lives in, the top-most level.
C:\ is the root of your hdd. C:\Windows is a subfolder of the root.
So you put the txt file alongside the VIDEO_TS folder, not IN it.
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 22:53 -
AVI (DivX) layer break issue with IMGburn on DL DVD's
By masherdude in forum Newbie / General discussionsReplies: 4Last Post: 31st Oct 2010, 12:22 -
Nero vs ImgBurn: Why is ImgBurn preferred?
By usually_quiet in forum Authoring (DVD)Replies: 31Last Post: 28th Aug 2010, 17:47 -
ImgBurn
By gomer in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2009, 23:35 -
Upgraded to ImgBurn 2.2 - Now "ImgBurn Shell Ext" No Longer Works
By Cool Breeze in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 11th May 2007, 10:05
