Hi, There is an issue that confused me. There many softwares in the market that fit complete Bluray movie BD50 disc to identically and same as source disc to BD25 discs. How they can do it? As far as I know sound files in Bluray movies (Dolby true hd, Dolby digital, DTS HD, DTS, etc.) couldn't be compressed because of their authorized structure. Then only remains Video file. When I look at these softwares they said they fit with same as original(same resolution, same format, same scale) then what is difference and how they can do this. And most crucial point is there a big difference in quality especially as watching at Full HD TV???![]()
They are either compressing it or stripping extra material. You can use free software to shrink like bd rebuilder.
Because they clone full disc, in my opinion they must compress video. If they achive BD25 only compressing video, I wonder how is the quality ?
Quality is quite good when going to 25gb blu ray disks. H264 is really outstanding for this. I prefer to remove extras though, when using BD Rebuilder. I rarely watch anything but the main movie.
Many movies will fit on a BD25 if you do movie-only. Others that won't quite fit otherwise can be made small enough if you use only the core audio, i.e. 640 kbps AC3.
BDRB can do the above for you. Or if you want full-disc, you can compress it to fit BD25. I really wouldn't worry about losing quality. As already mentioned, H.264 is highly efficient. You won't be able to tell the difference. It's hard to distinguish from the original even when compressing to BD9.
Good luck.Pull! Bang! Darn! -
Shortly before, I have tried full BD50 movie disc to BD25 cloning with one of the well known software. Astonishing but their is no difference in image and sound quality. May be an expert with very delicate tools can detect the difference but in normal watching at full HD Tv's there is no difference
How to shrink 3D BD50 to BD25
By danswano in forum Authoring (Blu-ray)Replies: 20Last Post: 23rd Oct 2013, 08:19 -
BD50 to BD25 and keep menus
By Eyecan'tcode in forum Blu-ray RippingReplies: 1Last Post: 24th Dec 2011, 19:26 -
Stupid question about BD50 to BD25
By timmus in forum Blu-ray RippingReplies: 2Last Post: 11th Sep 2010, 20:26 -
bd50 t0 bd25 from another region?
By tomrip in forum Blu-ray RippingReplies: 5Last Post: 16th Oct 2009, 15:41 -
Shrink BD50 to BD25
By mis3 in forum Blu-ray RippingReplies: 2Last Post: 5th Mar 2009, 07:54
