Can someone help me with what code I would need to convert an LG V8824W DVD/Video player so that it plays multi region disks... I want to be able to play both UK and USA dvds aswell as Australian if poss. I am not too technically mindedso will need step by step instructions on how to enter the codes aswell....
If you can help that would be great!
Jac
The following has been reported to work
1. Power on the player with no disk in the drive
2. Press "PAUSE" on the remote
3. Enter "3 1 4 1 5 9" on the remote (the word COdE appears on the display)
4. Enter "0" on the remote (0 = All Regions, 1 = Region 1, 2 = Region 2, etc.)
5. Press "PAUSE" on the remote
6. Power the player off and then back onRead my blog here.
Multi region codes for a Toshiba Sd7200 DVD player
By swany2 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 25th Feb 2012, 13:40 -
DVD multi-region player question...
By mjl1297 in forum Newbie / General discussionsReplies: 8Last Post: 26th Apr 2010, 06:05 -
DVD player: NAD T562 - Changing region codes
By FranSF in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th May 2009, 15:58 -
region free codes for sony dvd player
By andy7133 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Apr 2009, 09:58 -
Dodge/Chrysler DVD Player - any hacks for region codes?
By paulfnyc in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Nov 2007, 10:35
