Hello there folks.
I have spent a lot of time over the past week trying to find a video converter, using the CUDA capabilities, that can convert my .mkv 720 video, with 6 channel audio, into an .m4v file with the same discrete 6 channel audio. Every attempt so far has resulted in a clean picture, but all of the center channel audio ends up in the left speaker, while the remaining surround sound channels are consolidated into the right speaker. Have any of you succeeded in using any of these converters and generating a file that can be played with the new Apple TV, while generating a true 5.1 surround sound experience?
http://www.kiva.org/about -
It would also help if you told us what you had already tried so that we either don't suggest things you have already had problems with, or can suggest how you might make one that you have used work for you. I assume you are trying to encode the audio to 5.1 AAC ?
Read my blog here.
The ones that I have tried include ImTOO Apple TV Converter, Any Video Converter, Sothink Video Converter, and Xilisoft Video Converter Ultimate 6. I have ensured that the once that offer a 5.1 AAC are in face enabled. Of the ones that I have tried, none have succeeded in generating a 5.1 surround sound audio track on my system. Any help would be greatly appreciated.
Xmedia Recode supports AC3 audio in an AppleTV compatible format, so you could keep the original audio. Xvid4PSP can also output AppleTV compatible files, and will convert AC3 to AAC while preserving 5.1 surround.
Read my blog here.
Just two more questions about those suggestions.
1. Can they both convert the .mkv format?
2. Do either of them take advantage of the Nvidia Cuda speed boosts?
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Mkv converted for iTunes Apple TV keeping 5.1
By swindmiller in forum Newbie / General discussionsReplies: 0Last Post: 1st May 2012, 22:28 -
Comparison of 7 video converters: Converting a 720p mkv to 480p H.264
By srk in forum Video ConversionReplies: 2Last Post: 12th Oct 2010, 16:29 -
HDV to Apple PNG or Apple Motion JPEG A
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 1st Dec 2008, 16:46 -
Encode mkv to Apple TV
By popcop in forum Video ConversionReplies: 4Last Post: 19th Apr 2008, 06:21
