i recently just installed svcd2dvd and i cant seem to get it to register im running windows vista can someone please help me out i thought i could get it running but having no luck thanks guys.
Stand by. Chrissyboy usually stops by every couple of days and should be able to give you some specific assistance.
And welcome to our forums.
First basic questions- Did you install it in folder other than 'Program Files'? Are you running it as administrator?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
As you have vista - can you take a look at this thread about installation and Vista issues?
https://forum.videohelp.com/topic324278.html#1776530
(In particular: installation in a folder other than "Program Files" and running "As Administrator")SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
well ill be honest im not very sure how i saved it i dont want 2 seem stupid or what not but i checked the thread about run as administrator and i cant seem 2 even get the screen to come up to follow the steps for that so im really confused about this
I would then suggest you uninstall the program (Control Panel -->Add/Remove Programs) and reinstall in a folder other than 'Program Files', then go to that folder, right click on SVCD2DVD.exe and choose 'Run as administrator'.
Dwight
- Herm Albright
Need help troubleshooting video capture
By scorpio47 in forum Capturing and VCRReplies: 6Last Post: 13th Feb 2010, 02:48 -
M2TS troubleshooting
By vassock in forum Authoring (Blu-ray)Replies: 1Last Post: 11th Nov 2009, 01:45 -
Troubleshooting DV camcorder connectivity
By JohnnyMalaria in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 16th Mar 2008, 03:25 -
troubleshooting - empty file?
By Silky Slim in forum ffmpegX general discussionReplies: 4Last Post: 30th Jan 2008, 09:33 -
DVD playback troubleshooting
By mokodanu in forum Newbie / General discussionsReplies: 11Last Post: 3rd Sep 2007, 02:46
