I have a vizio hdtv and directv, but I needed to pick up some local channels that directv does not carry so I bought a outside antenna. Do I need to have the converter box the free one goverment was sending out, or do I just connect the outside antenna directly to my tv? Thanks.
http://www.kiva.org/about -
It is a VO320E. So you just cant hook up the antenna you have to point it in the right direction to receive the channel in HD even if it is broadcasting in HD? Thanks.
It has an ATSC tuner for tuning over-the-air digital broadcast. You don't need an external tuner.
The VO320E has a built in ATSC tuner. First you need to point the antenna, then select scan so the tuner can find the channels.
Issues.
1. The antenna must match the current TV bands for your area. VHF antennas receive ch 7-13, UHF antennas receive ch 14-51.
2. You need to point the antenna to the TV station towers. If you don't know the direction you can enter your address into
http://www.antennaweb.org/aw/Address.aspx
http://www.fcc.gov/mb/engineering/maps/
http://www.tvfool.com/index.php?option=com_content&task=view&id=13&Itemid=1
3. Then you let the tuner scan for channels.Last edited by edDV; 12th Oct 2010 at 22:55.
Digital Converter Box for TV (how to hook up)
By jay333 in forum Newbie / General discussionsReplies: 6Last Post: 10th Nov 2013, 21:02 -
What Digital TV Converter Box To Buy?
By Rayvyn007 in forum DVB / IPTVReplies: 58Last Post: 4th Jan 2013, 21:35 -
help with converter box to DVD player
By majel in forum DVB / IPTVReplies: 1Last Post: 13th Dec 2009, 08:14 -
On getting a DTV converter box...
By ahhaa in forum ComputerReplies: 0Last Post: 12th Apr 2008, 12:27 -
Digital TV Converter Box $9.95
By sushix in forum DVB / IPTVReplies: 1Last Post: 12th Mar 2008, 20:07
