  1. i have got some dvd movie files which is of very small duration of about 5 minutes. i have converted these from mp4 files to dvd format only to burn them in a dvd .(352*288,1200 kbps,4:3,@25 frames with 128 kbps joint stereo ,48 KHz). each file is about 80 MB. i would like to include around 50 files in one dvd. i want to get suggetions as to how can i accomplish the task. i dont want to burn the dvd as a data disk. instead it should be a movie disk.i would like to have a menu also with the the list of the files.any suggestions please.
    Apr 2004
    Miskatonic U
    DVD Styler ? GUIForDVDAuthor ? Both are free.
    Read my blog here.
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Also try avstodvd and multiavchd - both also free.
  4. thanks for the suggestions. but it seems that the suggested programmes need other softwares to run(avisynth etc)
    canada
    D/l avisynth,ffdshow,haali media splitter and then encode,most people here do that when told and have no problems after.
  6. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    GfD doesn't, if you have already encoded the videos to DVD compliant MPEG and AC3 audio.
    Mar 2008
    AVStoDVD, the installer package, will include and install those extra packages if you
    don't already have them.
