    Aug 2010
    Dallas, TX
    Hello, I have several interlaced .ts files I would like to be able to convert and burn them to a DVD. Other programs such as ConvertXtoDVD have not satisfied me since they deinterlace in a way which slows down the video from 30 frames(60 fields)/per second to just 30 frames per second. I would like to find a program which will be able to keep the fields intact so it looks how it should when played back on a DVD player.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Have you tried avstodvd or multiavchd? Both should do the conversion properly.
    Aug 2010
    Dallas, TX
    I tried multiavchd and I cannot find the file. Perhaps it failed. Here is the log:
    [20:54:57] Initialising...
    [20:54:57] Checking for new version...
    [20:54:58] You have the latest build.
    [20:54:58] Consistency check finished!
    [20:54:58] Initialization finished. multiAVCHD is ready!
    [20:54:58] 1 year and 290 days since multiAVCHD was published.
    [20:54:58] 370 people supported it with donations
    [20:54:58] and you are the 3571468 one to launch the program...
    [20:54:58] Support multiAVCHD to extend its features and keep it going!
    [20:54:58] multiAVCHD.dat version: [04010767]
    [20:58:57] [DVD]: Title#1 "SNL Gwenyth Paltrow 20100604 2345" auto-configured for smart transcoding to DVD format (video bitrate: 8000 kbps).
    [20:58:57] Checking for available space and drive types (FAT32/NTFS)...
    [20:59:00] Destination [C:]: NTFS, 155755.75 MiB (152.105 GiB) free space
    [20:59:00] Temp folder [c:]: NTFS, 155755.75 MiB (152.105 GiB) free space
    [20:59:00] Log started for multiAVCHD v4.1 (build 770)
    [20:59:00] Selected output mode: DVD player (DVD R/RW disc)
    [20:59:00] Processing one title...
    [20:59:00] Processing (G:\Video\SNL_Gwenyth_Paltrow_20100604_2345.ts)...
    [20:59:00] This title is marked for reencoding / uncropping...
    [20:59:00] Encoding process may take 10 min to 10 hours, so be patient...
    [20:59:00] *** Initiating video encoding:
    [20:59:00] *** Original : 1920x1080
    [20:59:00] *** Crop : 0
    [20:59:00] *** Resize : 720x480
    [20:59:00] *** Uncrop to : 720x480
    [20:59:00] *** Sharpen : 0
    [20:59:00] *** Bitrate : 8000 kbps
    [20:59:00] *** Frame rate: 23.976 (29.970)
    [20:59:00] *** Profile : SD-DVD (MPEG-2)
    [20:59:00] *** Encoding : Two pass - content: [00:01:10] (MPEG-2 encoder: HCenc)
    [21:02:19] *** Close to completion - closing preview...
    [21:03:14] *** Speed : 6.62 fps (elapsed: 00:04:14 - Realtime x 0.28)
    [21:03:14] *** Transcoding successful!
    [21:03:14] Detected video: ID#0:V_MPEG-2 720x480, fps=23.976
    [21:03:14] Display properties: 853x480 (AR:1.78)
    [21:03:14] Total of 1 tracks found in this file.
    [21:03:14] No audio tracks found!
    [21:03:14] Creating SD-DVD structure...
    [21:03:16] Demuxing 0 subtitle and 2 audio tracks...
    [21:03:16] No subtitles demuxed!
    [21:03:16] Processing 2 audio tracks...
    [21:03:18] Audio processing completed!
    [21:03:18] Applying pulldown...
    [21:03:19] Title contains: 2 audio tracks and 0 subtitle tracks
    [21:03:19] Authoring DVD structure (muxman)...
    [21:03:31] SD-DVD muxing completed!
    [21:03:31] SD-DVD title saved:
    [21:03:31] C:\Users\Nathan\Desktop\AVCHD\[DVD]\SNL Gwenyth Paltrow 20100604 2345
    [21:03:31] Compilation contains 1 (HD)DVD titles and no AVCHD/Blu-ray titles!
    [21:03:31] Setting pop-up menu...
    [21:03:31] *** Completed!
    [21:03:31] Preparing menu pages...
    [21:03:31] Setting main menu for 0 titles...
    [21:03:31] Selected TV system: [NTSC]
    [21:03:33] Done!
    Compilation summary:
    Format: DVD player (DVD R/RW disc) (mixed with DVD)
    1. 1 HD/SD-DVD titles
    Output size : 64 MiB (0.063 GiB)
    [21:03:33] C:\Users\Nathan\Desktop\AVCHD folder created (AVCHD/Blu-ray output)!
    [21:03:33] Burn its CONTENTS to DVD R/RW UDF 2.50/2.60 disc!
    [21:03:34] Compilation contains HD-DVD/SD-DVD titles placed in [HD-DVD]/[DVD] folder.
    [21:03:34] Burn each HD-DVD/SD-DVD title folder contents (both HVDVD_TS and VIDEO_TS for HD-DVD) to a separate DVD disc.
    [21:03:35] You may now remove temp folder (c:\multiAVCHD\_TEMP\multiTEMP-20101012\).
    [21:03:35] multiAVCHD finished in 275.25 seconds (00:04:35.250)!
    [21:03:35] End of log.
    [21:03:35] Cleaning up...
    [21:03:36] Done!
    [21:03:36] DELETE EXCEPTION: Should not touch folder! (C:\Users\Nathan\Desktop\AVCHD\AVCHDTN\)
    [21:03:36] For technical support, bug reports and questions:
    [21:03:36] http://multiFORUM.deanBG.com/
    [21:03:36] http://multiAVCHD.deanBG.com/
    [21:03:36] http://multiAVCHD.deanBG.com/doom9/
    [21:03:36] For latest download links and tools visit:
    [21:03:36] http://multiFORUM.deanBG.com/downloads/
    [21:06:46] Checking for available space and drive types (FAT32/NTFS)...
    [21:06:48] Destination [C:]: NTFS, 155691.55 MiB (152.043 GiB) free space
    [21:06:48] Temp folder [c:]: NTFS, 155691.55 MiB (152.043 GiB) free space
    [21:06:48] Log started for multiAVCHD v4.1 (build 770)
    [21:06:48] Selected output mode: Panasonic Camcoder (SDHC) (NTSC)
    [21:06:48] Processing one title...
    [21:06:48] Existing C:\Users\Nathan\Desktop\AVCHD\ cannot be used as destination folder!
    [21:06:48] Output will be written to: C:\Users\Nathan\Desktop\AVCHD-20101012-210648
    [21:06:49] Processing (c:\multiAVCHD\_TEMP\multiTEMP-20101012\SNL_Gwenyth_Paltrow_20100604_2345.[720x480-23.976].m2v)...
    [21:06:49] This title is marked for reencoding / uncropping...
    [21:06:49] Encoding process may take 10 min to 10 hours, so be patient...
    [21:06:49] *** Initiating video encoding:
    [21:06:49] *** Original : 720x480
    [21:06:49] *** Crop : 0
    [21:06:49] *** Resize : 720x480
    [21:06:49] *** Uncrop to : 720x480
    [21:06:49] *** Sharpen : 0
    [21:06:49] *** Bitrate : 8000 kbps
    [21:06:49] *** Frame rate: 23.976 (23.976)
    [21:06:49] *** Re-packing elementary V_MPEG-2 stream...
    [21:06:49] *** Profile : SD-DVD (MPEG-2)
    [21:06:49] *** Encoding : Two pass - content: [00:01:10] (MPEG-2 encoder: HCenc)
    [21:07:00] *** Speed : 146.75 fps (elapsed: 00:00:11 - Realtime x 6.12)
    [21:07:00] *** Transcoding failed!
    [21:07:00] *** Check ffdshow/avisynth/haali (reinstall)!
    [21:07:00] >>> Download links: http://multiforum.deanbg.com/viewtopic.php?f=7&t=17
    [21:07:00] *** DEBUG: Try to play [c:\multiAVCHD\_TEMP\multiTEMP-20101012\20101012-210649-uncrop-running.avs] in MPC or other player, which supports AviSynth scripts and report the error to the author!
    [21:07:00] Retrying to transcode with FFMS2!
    [21:07:00] Stand-by for indexing...
    [21:07:00] *** Initiating video encoding:
    [21:07:00] *** Original : 720x480
    [21:07:00] *** Crop : 0
    [21:07:00] *** Resize : 720x480
    [21:07:00] *** Uncrop to : 720x480
    [21:07:00] *** Sharpen : 0
    [21:07:00] *** Bitrate : 8000 kbps
    [21:07:00] *** Frame rate: 23.976 (23.976)
    [21:07:00] *** Re-packing elementary V_MPEG-2 stream...
    [21:07:00] *** Profile : SD-DVD (MPEG-2)
    [21:07:00] *** Stand-by for indexing (ffms2)...
    [21:07:00] *** Encoding : Two pass - content: [00:01:10] (MPEG-2 encoder: HCenc)
    [21:07:12] *** Speed : 143.24 fps (elapsed: 00:00:11 - Realtime x 5.97)
    [21:07:12] *** Transcoding failed!
    [21:07:12] *** Check ffdshow/avisynth/haali (reinstall)!
    [21:07:12] >>> Download links: http://multiforum.deanbg.com/viewtopic.php?f=7&t=17
    [21:07:12] *** DEBUG: Try to play [c:\multiAVCHD\_TEMP\multiTEMP-20101012\20101012-210700-uncrop-running.avs] in MPC or other player, which supports AviSynth scripts and report the error to the author!
    [21:07:12] ERROR: Compilation does not contain any HD-DVD/AVCHD/Blu-ray titles!
    [21:07:12] Authoring menu (NTSC).
    [21:07:12] Creating title thumbnails for 0 titles (XMB)...
    [21:07:12] Image processing for XMB menu completed!
    [21:07:12] Setting main menu for 0 titles...
    [21:07:12] Selected TV system: [NTSC]
    [21:07:13] Applying SDHC parameters...
    [21:07:13] Preparing AVCHDTN database...
    [21:07:13] Database and index created!
    [21:07:13] Done!
    Format: Panasonic Camcoder (SDHC) (NTSC)
    Output size : 2 MiB (0.001 GiB)
    [21:07:13] C:\Users\Nathan\Desktop\AVCHD-20101012-210648 folder created (AVCHD/Blu-ray output)!
    [21:07:13] Copy C:\Users\Nathan\Desktop\AVCHD-20101012-210648 to X:\PRIVATE\ of SDHC/SD/MMC card.
    [21:07:13] or SD_VIDEO and PRIVATE to root of your SDHC/SD/MMC card.
    [21:07:14] You may now remove temp folder (c:\multiAVCHD\_TEMP\multiTEMP-20101012\).
    [21:07:14] multiAVCHD finished in 25.797 seconds (00:00:25.797)!
    [21:07:14] End of log.
    [21:07:14] Cleaning up...
    [21:07:14] Done!
    [21:07:14] For technical support, bug reports and questions:
    [21:07:14] http://multiFORUM.deanBG.com/
    [21:07:14] http://multiAVCHD.deanBG.com/
    [21:07:14] http://multiAVCHD.deanBG.com/doom9/
    [21:07:14] For latest download links and tools visit:
    [21:07:14] http://multiFORUM.deanBG.com/downloads/
    [21:11:31] Checking for available space and drive types (FAT32/NTFS)...
    [21:11:33] Destination [G:]: NTFS, 1141228.77 MiB (1114.481 GiB) free space
    [21:11:33] Temp folder [c:]: NTFS, 155691.09 MiB (152.042 GiB) free space
    [21:11:33] Log started for multiAVCHD v4.1 (build 770)
    [21:11:33] Selected output mode: Panasonic Camcoder (SDHC) (NTSC)
    [21:11:33] Processing one title...
    [21:11:33] Processing (c:\multiAVCHD\_TEMP\multiTEMP-20101012\SNL_Gwenyth_Paltrow_20100604_2345.[720x480-23.976].m2v)...
    [21:11:33] This title is marked for reencoding / uncropping...
    [21:11:33] Encoding process may take 10 min to 10 hours, so be patient...
    [21:11:33] *** Initiating video encoding:
    [21:11:33] *** Original : 720x480
    [21:11:33] *** Crop : 0
    [21:11:33] *** Resize : 720x480
    [21:11:33] *** Uncrop to : 720x480
    [21:11:33] *** Sharpen : 0
    [21:11:33] *** Bitrate : 8000 kbps
    [21:11:33] *** Frame rate: 23.976 (23.976)
    [21:11:33] *** Re-packing elementary V_MPEG-2 stream...
    [21:11:33] *** Profile : SD-DVD (MPEG-2)
    [21:11:33] *** Encoding : Two pass - content: [00:01:10] (MPEG-2 encoder: HCenc)
    [21:11:44] *** Speed : 151.29 fps (elapsed: 00:00:11 - Realtime x 6.31)
    [21:11:44] *** Transcoding failed!
    [21:11:44] *** Check ffdshow/avisynth/haali (reinstall)!
    [21:11:44] >>> Download links: http://multiforum.deanbg.com/viewtopic.php?f=7&t=17
    [21:11:44] *** DEBUG: Try to play [c:\multiAVCHD\_TEMP\multiTEMP-20101012\20101012-211133-uncrop-running.avs] in MPC or other player, which supports AviSynth scripts and report the error to the author!
    [21:11:44] Retrying to transcode with FFMS2!
    [21:11:44] Stand-by for indexing...
    [21:11:44] *** Initiating video encoding:
    [21:11:44] *** Original : 720x480
    [21:11:44] *** Crop : 0
    [21:11:44] *** Resize : 720x480
    [21:11:44] *** Uncrop to : 720x480
    [21:11:44] *** Sharpen : 0
    [21:11:44] *** Bitrate : 8000 kbps
    [21:11:44] *** Frame rate: 23.976 (23.976)
    [21:11:44] *** Re-packing elementary V_MPEG-2 stream...
    [21:11:44] *** Profile : SD-DVD (MPEG-2)
    [21:11:44] *** Stand-by for indexing (ffms2)...
    [21:11:44] *** Encoding : Two pass - content: [00:01:10] (MPEG-2 encoder: HCenc)
    [21:11:56] *** Speed : 151.07 fps (elapsed: 00:00:11 - Realtime x 6.3)
    [21:11:56] *** Transcoding failed!
    [21:11:56] *** Check ffdshow/avisynth/haali (reinstall)!
    [21:11:56] >>> Download links: http://multiforum.deanbg.com/viewtopic.php?f=7&t=17
    [21:11:56] *** DEBUG: Try to play [c:\multiAVCHD\_TEMP\multiTEMP-20101012\20101012-211144-uncrop-running.avs] in MPC or other player, which supports AviSynth scripts and report the error to the author!
