The title says it all.
I've installed avisynth batch scripter 1.0.1 and it worked fine.
The second time i opened the program it wouldn't work. When I try to set a folder i get the run-time error '380', invalid property value.
Is there an easy fix? Googling suggest using a registry fix but I don't wanna mess up other programs.
I had this problem one other time but I posted it in a correct forum.
Actually what I did was order 2 loaded pizza's and everything worked after that. -
Didn't know which forum this should go so put it in here jsut to be save. Guess it's suppose to be in video conversion?
Sorry for double posting didn't know pming moderator was an option ^_^
Problem solved by the way simply reinstalled the program... Although I did it once already. Hope it sticks.
DVD Flick Run-Time Error 13
By amrcnbut in forum Video ConversionReplies: 2Last Post: 28th May 2011, 15:50 -
DVDAuthorGui run-time error 75
By boborg in forum Authoring (DVD)Replies: 4Last Post: 16th Jan 2009, 14:37 -
Avisynth Batch Scripter
By stevenca in forum EditingReplies: 0Last Post: 7th Apr 2008, 02:30 -
Rebuilder Run-time error ‘52’
By coody in forum DVD RippingReplies: 2Last Post: 4th Jan 2008, 11:03
