  1. I'm trying to make XVCD of the movie Gladiator but running into a little problem.
    Nero said that it's VCD2 and not suitable to record as VCD, plus when I play the VCD it play fine but I can't fastfoward it.
    I'm going to list the steps that I did:
    1st: Rip with smart ripper
    2nd: Frame serving with DVD2AVI, I used Force Film because the auto detect said that it was FILM99% but instead of turning to 23.967 like it should it turned into 24.000, and showing the ratio is 16:9
    3rd: I used TMPGEnc to encode using the VideoCD 1246kbps (NTSC) template, and the setting are as follow: (i'm just going to list the important one, and the bold word are the tabs)
    Video
    Aspect Ratio: 4:3 525 line (NTSC)
    Frame Rate: 24
    Rate Control Mode: CBR
    Bitrate: 3000
    Advance
    Video Source Type: Interlace
    Source Aspect Ratio: 16:9 525 line (NTSC)
    Full Screen: Keep Aspect Ratio 2
    Sorry for the long post but I need to get the facts in so you guys have enough info to help me.
  2. how do you know it turned into 24fps? encode 23.976 regardless, sync the audio if you have to. also, your source type is progessive after forced film
