As there are plenty of developers here who are sharing great video tools.
I guess, Video Sample having TWO AC3 and PCM, with en-SUB might be useful for developments of video players, video converters.
download links:
LINK-1
1) http://rapidshare.com/files/424560778/video_sample_ac3_n_pcm_with_sub_.vob
alternate link
2) http://rapidshare.com/files/424560883/video_sample_ac3_n_pcm_with_sub_.vob
Media Info:
General
Complete name : video_sample[ac3 n pcm with sub].vob
Format : MPEG-PS
File size : 114 MiB
Duration : 3mn 22s
Overall bit rate : 4 729 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=15
Duration : 2mn 33s
Bit rate mode : Variable
Bit rate : 2 651 Kbps
Nominal bit rate : 8 000 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.256
Stream size : 48.4 MiB (42%)
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Duration : 2mn 33s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Video delay : -48s 754ms
Stream size : 8.21 MiB (7%)
Audio #2
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Signed
Muxing mode : DVD-Video
Duration : 3mn 22s
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Bit depth : 16 bits
Video delay : -48s 839ms
Stream size : 37.1 MiB (32%)
Text#1 : enSUB.srt
Moderator can move this post to appropriate channel.
another better video clip with multi audio and multi-SUBed eN-Fr-Es) is here, many videop layers fails to offer selection.
DOWNLOAD LINK
http://rapidshare.com/files/424737190/VideoSampleClip.mpeg
General
Complete name : VideoSampleClip.mpeg
Format : MPEG-PS
File size : 73.0 MiB
Duration : 2mn 36s
Overall bit rate : 3 909 Kbps
Video
Format : MPEG Video
Duration : 2mn 36s
Bit rate : 2 807 Kbps
Nominal bit rate : 9 800 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Standard : Component
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Scan order : 2:3 Pulldown
Bits/(Pixel*Frame) : 0.339
Stream size : 52.3 MiB (72%)
Audio #1
Format : AC-3
Duration : 2mn 36s
Bit rate : 448 Kbps
Bit depth : 16 bits
Video delay : -78ms
Stream size : 8.36 MiB (11%)
Audio #2
Format : AC-3
Format profile : Dolby Digital
Duration : 2mn 36s
Bit rate : 192 Kbps
Bit depth : 16 bits
Video delay : -78ms
Stream size : 3.58 MiB (5%)
Audio #3
Format : AC-3
Duration : 2mn 36s
Bit rate : 192 Kbps
Bit depth : 16 bits
Video delay : -78ms
Audio #4
Format : AC-3
Duration : 2mn 36s
Bit rate : 192 Kbps
Bit depth : 16 bits
Video delay : -78ms
Text #1
Format : RLE
Format/Info : Run-length encoding
Duration : 2mn 33s
Video delay : 751ms
Text #2
Format : RLE
Duration : 2mn 33s
Video delay : 751ms
Text #3
ID : 224 (0xE0)-DVD-2
Format : EIA-608
Muxing mode, more info : Muxed in Video #1
Stream size : 0.00 Byte (0%)
Text #4
Format : RLE
Text #5
Format : RLE
Shrinking entire dvd with pcm to ac3
By emodio80 in forum Newbie / General discussionsReplies: 29Last Post: 26th Jul 2011, 05:17 -
DTS n AC3 Muti Audio Sample
By Bonie81 in forum ProgrammingReplies: 0Last Post: 28th Dec 2010, 21:09 -
Convert PCM to AC3???
By ivano09 in forum Video ConversionReplies: 6Last Post: 17th Feb 2010, 13:08 -
PCM vs AC3
By Reading Bug in forum AudioReplies: 14Last Post: 1st May 2009, 05:34 -
AC3 audio is output as PCM to my receiver using SPDIF connection
By Daft in forum AudioReplies: 8Last Post: 7th Mar 2008, 15:45
