After one successful attempt, AVStoDVD started crashing every time.
Following is the LOG for short-run for testing
DVD log
<10/12/2010 2:07:31 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 128/100 MB (128%)
DVD Output Setup: DVD Folder
DVD Label: DVD
DVD Menu: Motion Menu
Output Folder: C:\AVS2DVD-OUT
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command ParPMeters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
Video Resolution: 1
Video BitRate Min: 2500
Video BitRate Level 1: 8500
Video Profile Level 2: 2500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 1
PAL SpeedUp: 0
Force FFmpeg for Long Audio: True
DVD Audio Format: 0
DVD Audio BitRate: 448
Keep DVD Compliant Audio: 1
Normalize Audio: 0
DVD Audio Language: EN - English
DVD Subs Language: EN - English
DVD Subs Font: Tahoma 18pt Bold
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: D: TSSTcorp CDDVDW TS-H652J UO00
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Save General Settings: 0
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
TITLE 1 SOURCE FILES
Video: C:\DVD_AVI\video.d2v
Info: DGIndex - 1470 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 5:27
minutes - 7854 frPMes
Audio 1: C:\DVD_AVI\video T80 3_2ch 448Kbps DELAY 0ms.ac3
Info: AC3 - 448 kbps - CBR - 6ch - 48000Hz - 5:26 minutes - External
Subs:
[A2DInfo.avsi]
AVISYNTH SCRIPT
Import("C:\AVS2DVD\Lib\A2DSource.avsi")
LoadPlugin("C:\AVS2DVD\DGIndex\DGDecode.dll")
Video = MPEG2Source("C:\DVD_AVI\video.d2v")
# Audio is frPMeserved by AviSynth just for Preview and Edit purposes.
Audio = A2DAudioSource("C:\DVD_AVI\video T80 3_2ch 448Kbps DELAY 0ms.ac3",
CacheFolder="C:\AVS2DVD\temp")
Video = Video.ConvertToYV12
Video = Video.ConvertFPS("ntsc_video")
AudioDub(Video, Audio)
<10/12/2010 2:07:34 PM>
TITLE 1 AVISYNTH FRPMESERVING CHECK
Check passed successfully.
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 97.8 MB
HCenc ParPMeters: -ini "C:\AVS2DVD\temp\DVD_video.HCenc.ini"
HCenc ini file:
*INFILE C:\AVS2DVD\temp\DVD_video_1.avs
*AVSRELOAD
*OUTFILE C:\AVS2DVD-OUT\DVD_video.m2v
*LOGFILE C:\AVS2DVD\temp\DVD_video.HCenc.log
*MAXBITRATE 9000
*BITRATE 2500
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 20
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<10/12/2010 2:49:58 PM>
END VIDEO ENCODING OPERATIONS
Created File: C:\AVS2DVD-OUT\DVD_video.m2v (97.7 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 2518 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) -
Progressive (TFF) - 5:27 minutes - 9806 frPMes
START AUDIO DEMUXING OPERATIONS (Track 1)
FFmpeg ParPMeters: -i "C:\DVD_AVI\video T80 3_2ch 448Kbps DELAY 0ms.ac3" -acodec copy
"C:\AVS2DVD-OUT\DVD_video_1.ToFix.ac3"
<10/12/2010 2:50:17 PM>
END AUDIO ENCODING OPERATIONS (Track 1)
Created File: C:\AVS2DVD-OUT\DVD_video_1.ac3 (17.4 MB)
OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 6ch - 48000Hz - 16bit - 5:26 minutes
<10/12/2010 2:50:18 PM>
START DVD MENU BUILDING OPERATIONS
DVD Menu settings: Style 1, DAR 1, Titles Format 1, Video BitRate 6000, Menu Pages 1, Menu
Titles 1
<10/12/2010 2:50:29 PM>
END DVD MENU BUILDING OPERATIONS
Created File (Menu Page 1): C:\AVS2DVD-OUT\DVD_MenuPage1.m2v (0 MB)
START DVD AUTHORING OPERATIONS
BatchMux ParPMeters: -arglist "C:\AVS2DVD\temp\DVD_BatchMux.ini"
BatchMux ini file:
-d "C:\AVS2DVD-OUT\DVD\VIDEO_TS"
-mxp "C:\AVS2DVD\temp\DVD_MuxMan.mxp"
-l "C:\AVS2DVD\temp\DVD_MuxMan.log"
-muxman "C:\AVS2DVD\MuxMan"
-prio LOW
-v "C:\AVS2DVD-OUT\DVD_video.m2v"
-vidmode LB
-a1 "C:\AVS2DVD-OUT\DVD_video_1.ac3"
-a1lang en
-cellfr "C:\AVS2DVD-OUT\DVD_video_Chapters.txt"
-progfr "C:\AVS2DVD-OUT\DVD_video_Chapters.txt"
-chapfr "C:\AVS2DVD-OUT\DVD_video_Chapters.txt"
-SEG2v "C:\AVS2DVD-OUT\DVD_MenuPage1.m2v"
-SEG2vidmode LB
-SEG2s1 "C:\AVS2DVD-OUT\DVD_Menu.sst"
-SEG2s1dmode WIDE_LB
-SEG2hlmnu "C:\AVS2DVD\temp\DVD_MenuPage1_Buttons.mnu"
-SEG2hlcsm "C:\AVS2DVD\temp\DVD_HighlightScheme.csm
-hcn "C:\AVS2DVD\temp\DVD_BatchMux.hcn"
<10/12/2010 2:50:57 PM>
PROCESS ABORTED DURING DVD AUTHORING OPERATIONS!
CHECK FOLLOWING FILES FOR MORE DETAILS:
AVSTODVD LOG FILE <C:\AVS2DVD-OUT\DVD.LOG>
BATCHMUX LOG FILE <C:\AVS2DVD-OUT\DVD_BATCHMUX.LOG>
<10/12/2010 2:51:03 PM>
Log file created by AVStoDVD Release 2.3.2 Alpha build 100910
DVD Batchmux Log
BatchMux version --> 1.3
Destination Folder --> C:\AVS2DVD-OUT\DVD\VIDEO_TS
MuxMan Script File --> C:\AVS2DVD\temp\DVD_MuxMan.mxp
MuxMan Log String --> -l "C:\AVS2DVD\temp\DVD_MuxMan.log"
Folder of the MuxMan executable --> C:\AVS2DVD\MuxMan
Check presence of MuxMan.exe --> PASSED
Segment #1 - Video File #1 --> C:\AVS2DVD-OUT\DVD_video.m2v
Checking asset for importing as --> M2V, M1V, MPV
Video Coding Mode --> MPEG-2
Video Resolution (Nominal) --> (720x480)
MPEG-2 Aspect Ratio (DAR) --> 16:9
Video Frame Rate --> 29,97 fps
Video Bitrate (Nominal, Kbps) --> 8789
VBV Buffer Size (Kbyte) --> 224
Segment #1 - Video Display Mode --> LB
Segment #1 - Audio #1 File #1 --> C:\AVS2DVD-OUT\DVD_video_1.ac3
Segment #1 - Audio Lang Code #1 --> en
Segment #1 - Timeframe file --> C:\AVS2DVD-OUT\DVD_video_Chapters.txt
Segment #1 - Total Nr of Cells --> 2
Segment #1 - Total Nr of ProgrPMs --> 2
Segment #1 - Total Nr of Chapters --> 2
Segment #2 - Video File #1 --> C:\AVS2DVD-OUT\DVD_MenuPage1.m2v
Segment memory resources --> RELEASED
Local Stack memory --> RELEASED
File i/o structures --> DEALLOCATED
any help?
There's something wrong with the menu creation step. See log file section:
0 MB means that menu file has not been created. Possible causes are:<10/12/2010 2:50:29 PM>
- QuEnc has crashed during menu creation
- You set 0 seconds in DVD Menu Wizard
Anyway, if you can go to DVD Menu Editor and edit the menu elements, then menu creation should be ok as well. Can you go to DVD Menu Editor withour errors?
Bye -
Thanks 4 reply.
i guess it may be "I forgot to set 0 seconds in DVD Menu Wizard"
i am already enjoying 56 min DVD without menu.
Tks
Got success with static menu with text.
Still crashing for Motion Menu with movie thumbnails., all settings were double-checked n verified.
Over all Good Quality, and...
AVStoDVD Great DVD Authoring Tool and simple too!
PS: _MrC_ just got A+ for AVStoDVD
AVStoDVD 2.4.0
By Hoser Rob in forum Authoring (DVD)Replies: 0Last Post: 30th May 2011, 20:37 -
AVStoDVD Subtitle
By bebado22 in forum Video ConversionReplies: 6Last Post: 22nd Oct 2010, 05:26 -
AVStoDVD
By Dooker in forum Authoring (DVD)Replies: 10Last Post: 24th Aug 2009, 07:29 -
AVStoDVD but than VCD
By B-Twien Bytes in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jun 2009, 16:30 -
AVStoDVD!
By Milardo in forum Authoring (DVD)Replies: 12Last Post: 15th Feb 2009, 05:01
