Hi
What is the preferred format and revision for burning Xvid and Divx files over 1.5 gig onto DVD-R. Both my players quit at about 1 gig when format is ISO/Joliet. The players are toshiba and Philips.
Save them into <1 GB segments with VirtualDub without reencoding the audio or video.
1) File -> Open Video File
2) Video -> Direct Stream Copy
3) File -> Save Segmented AVI (set size limit to 999 MB)
This will only take about 30 seconds. -
You can also try UDF, which supports larger file sizes. If you want to test it, burn to a re-writable disc because there is some chance your players may not like it. I'd use UDF 2.01 and not a higher version. I just suggest this as an alternative to splitting the files, but jagabo's suggestion will certainly solve your problem.
How to create a DVD using multiple DIVX/XVID files with Menu
By Amourek in forum User guidesReplies: 2Last Post: 2nd Mar 2009, 09:57 -
What's the best format DivX or Xvid I can get?
By OM2 in forum Newbie / General discussionsReplies: 7Last Post: 19th Jan 2009, 15:59 -
Does divx author reencode Divx and xvid files?
By Onceler2 in forum DVD RippingReplies: 4Last Post: 26th Aug 2008, 19:16 -
MP4 files in MOV format - how to play in dvd/divx player
By glen_s in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2007, 04:49 -
Multiple Divx/Xvid files on DVD w/ menus and selectable subs?
By louv68 in forum DVD RippingReplies: 4Last Post: 18th Jul 2007, 09:01
