I am very new to this, not sure is this is the right place for this or not. I have an issue with my Patariot Box Office playing mkv files, I know there are many stand alone media players with issues playing mkv files due to header compression I have used mkvtoolnix to fix the header problem which works great and plays on my PBO but the new muxed file only shows half of the movie??? The size of old file and new file are same the header problem got fixed but why does it only play first hour or so of the movie?? Can anyone help me or faced similar issue and can guide me if I am doing something wrong.
Thank you.
I only had one similar experience and it was the fault with the movie. My device was a Seagate player. The movie got to a certain point and stopped. Within a second or 2 the player rejected the rest of the movie. I re-converted the movie to MKV and it was fine.
Tony
Adding subtitles to MKV container via mkvtoolnix
By subbin in forum EditingReplies: 1Last Post: 30th Jun 2011, 02:28 -
I lose MKV thumbnails when remuxing with MKVToolnix!
By Ollielufti in forum EditingReplies: 4Last Post: 5th Oct 2010, 17:17 -
Cutting/Merging MKV file - Mkvtoolnix
By FMFIA in forum EditingReplies: 1Last Post: 15th Aug 2010, 00:47 -
Remuxed mkv using mkvtoolnix leaves file unplayable
By micnolmad in forum Video ConversionReplies: 4Last Post: 10th Jul 2010, 11:33 -
Need to add English AC3 to MKV - MKVToolnix Crashing
By kardashian in forum MacReplies: 6Last Post: 18th May 2009, 08:31
