If I have my PS3 outputting composite, which is plugged in to the input of my VCR and I have a male to male Component cable from the output of the VCR to a 22" Toshiba LCD Monitor, would I get a very good increase in quality (as if I were using Component directly) or does the quality increase when it is actually outputted (meaning that at the end, i'll only have a good composite quality)? Aside from that, do you think there would be a huge change between Component and HDMI, or a small, tolerable change?
Results 1 to 14 of 14
Your VCR will not increase the quality of the component signal. If you want good quality on the monitor run HD component or HDMI directly from the PS3 to the monitor.
No, I mean, will the composite literally TURN into component, as if I were directly using component, not outputting composite? the reason I want this is to get decent quality while I record my game play, since the Composite output of the VCR will be plugged in to my recording device, and I want to play and record simultaneously. Please reply. Thanks in advance!
Can you plug directly into the recording device?
The fewer links in the chain......the better chance at quality.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
I think you're best bet is to invest in a hauppuage hd pvr. That is by far the best way to go. You get crisp clean 16:9 high def video with surround sound (via component input to the hdpvr and 5.1 audio via a fiber optic cable).
Its a bit pricey to be sure but you get excellent results and can downconvert to a quality dvd if you can't do bluray and/or avchd.
Edit - and by the way the hdpvr does have component passthrough to send to the tv while capturing.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Even an old PVR-250 via S-VHS would be better than composite.
AND - there shouldn't be much of a delay - the Hauupauge cards have onboard encoders - do not use your processor.;/ l ,[____], Its a Jeep thing,
Whether or not the VCR will convert composite to component depends on the VCR. Unless it's a very high end VCR my guess is no. Even if it does convert, the picture quality isn't likely to be any better than running composite all the way.
I know you're not interested but... the Hauppauge PVR-250 normally has a half second or so delay between the live action and what you see on the computer screen. There is a registry hack that decreases that to only a frame or so. -
Video Capture Device Suggestion - For VCR & PS3
By dan1st in forum Capturing and VCRReplies: 5Last Post: 23rd Aug 2011, 13:33 -
need encoding tips for better quality PS3-friendly MP4
By spicediver10191 in forum Video ConversionReplies: 6Last Post: 13th Mar 2011, 05:48 -
High Quality DVD vobs to PS3
By The_Lurker in forum DVD RippingReplies: 6Last Post: 14th Oct 2008, 08:49 -
Copy DVD to ??? for highest quality streaming to PS3 and archiving
By FreeLunch in forum DVD RippingReplies: 2Last Post: 30th Sep 2008, 22:44 -
How to get AVCHD on Harddrive of PS3 without loosing quality
By alex1357 in forum Video ConversionReplies: 2Last Post: 7th Jun 2008, 10:06
