Results 1 to 9 of 9
  1. I need a directshow filter for the Animation codec. Can somebody help me? Thanks.
  2. What animation codec? Use MediaInfo or GSpot to get detailed information about the codec. ffdshow has decoders for most common codecs.
  3. Originally Posted by jagabo View Post
    http://en.wikipedia.org/wiki/Animation_codec
    ffdshow doesn't seem to support it.
  4. Look for "QTRLE" in ffdshow and enable it
    You need a directshow splitter for MOV . I don't know of any free ones, but nero has one
    What are you trying to do that needs to use directshow ?
  5. Originally Posted by poisondeathray View Post
    It appears to be enabled, but nothing is working :/.
    I want to encode the video using x264.
  6. Originally Posted by roflwaffle View Post
    Don't use directshow to encode; it's not necessarily frame accurate and can give problems. The reason it's not working for you is probably your pins don't connect (you don't have a MOV splitter)
    Use ffmpegsource2
    http://code.google.com/p/ffmpegsource/
    e.g.
    vid=FFVideoSource("video.mov")
    aud=FFAudioSource("video.mov")
    AudioDub(vid,aud)
    ConvertToYV12() #use interlaced=true if your format is interlaced
  7. Originally Posted by poisondeathray View Post
    Use ffmpegsource2
    e.g.
    AudioDub(vid,aud)
    Thanks, I'll look at this tomorrow .
  8. Originally Posted by roflwaffle View Post
    Just to be sure: ffdshow has both VFW and DirectShow decoders. Be sure you enabled the right one. Start -> All Programs -> ffdshow -> Video Decoder Configuration.
  9. Originally Posted by poisondeathray View Post
    Use ffmpegsource2
    e.g.
    AudioDub(vid,aud)
    Oops- before I forget, thanks . I tried it a while back and it worked.
