Is that possible?
if yes, how?
please help
thanks a lot/Fabio
Imgburn is a burning tool not an authoring tool.
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
ok I have some files .iso and would like to burn a dvd ( with chapters and so on)
which sw do you suggest?
thanks -
Ahhhh, much better question and you've given us more info.
If its a DVD iso, extract the audio/video folder with a tool like isobuster. Extract the VOBs with VOB2MPG to a single .mpg (mpeg2) file. Import the mpeg2 into a authoring tool like TMPG Author, DVD Movie Factory, DVD Flick, even Windows Movie maker will do ... to generate new VOBs with the menus/chapters of your choice. Use tools that will reencode as little as possbile so lose a little quality as possible. Editting mpeg2 can be tricky. Look at payware that will do the job.
- Create/Capture
- Edit
- Author
- Burn
Rise, repeat as necessary.
Some tools will combine the above steps but there's no way around them. Look at the What Is - DVD, Tools, and How-To guides to the left. Tons of very helpful info.Have a good one,
neomaine
@neomaine - I think you meant Windows DVD Maker, not Windows Movie Maker
@the OP - if this is an ISO of a DVD then it may well already have chapters etc. from when it was originally authored. You could either extract or mount the ISO, then play the contents form the video_ts folder in a good software player and test this before going to any further trouble.Read my blog here.
I didn't think of Win DVD Maker and meant to say Movie Maker. Though, I think it has the option to only create a compliant mpeg2 like for a slideshow. Not sure about chapters. Been a while since I've used it.
DVD maker makes much more sense.Have a good one,
neomaine
DVDStyler Not Creating Chapters?
By analytalica in forum Authoring (DVD)Replies: 1Last Post: 31st Mar 2012, 19:10 -
Creating chapters (MKV)
By ignorantbliss in forum Newbie / General discussionsReplies: 1Last Post: 4th May 2010, 11:32 -
Creating MDS file automatically When ripping to ISO With ImgBurn
By bbanderic in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2010, 22:53 -
VOB2MPG not creating chapters
By marsh89 in forum DVD RippingReplies: 5Last Post: 15th Sep 2007, 09:22 -
Creating chapters using CCE
By hipatuga1 in forum Authoring (DVD)Replies: 3Last Post: 5th May 2007, 05:10
