Hello I have 7 MKV files with ending tags .......1080p.HDV.h264-vEsD@RiS.mkv. I think the vEsD@RiS part is just the poster. OK When I first downloaded them I had no problems viewing them using K-Lite-Mega-Codec-Pack.v.5.0.0. There may have been a proper codec already installed but I don't know now, but since I've reformatted my system, and using K-Lite-Mega-Codec-Pack.v.5.0.0 the audio is out of sync by a second or two. So now My system is reformatted again as I post this. I've installed no codecs at all hoping to get the correct codec for the 108p HDV h264 mkv files from the board. Please advise, Thanks!
If your listed system specs are correct, you won't get realtime playback for 1080p
You need to upgrade hardware -
Dump, if you can, any and all 'codec packs'. All you need for playback is a self-contained player likc MPCHC or VLC. You don't need the potential, and very often realized, confusion and system issues of multiple codecs and 'packs' (shiver ...
) to just play media.
I highly recommend a minimalist approach to codecs.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
If your system was playing the video and audio, even if out of sync, then you do (or did) have all the codecs you need.
Lag could be due to your hardware not being able to render in real time.
K-Lite probably set up ffdshow to play MKVs.
I've heard claims that CoreAVC is more efficient H264 decoder.
Never tried it myself, but you may look into it.
audio out of sync with MKV files, but an inferior computer plays perfect
By dave in or in forum AudioReplies: 3Last Post: 4th Aug 2011, 15:32 -
Video scattering , audio sync variable delay in MKV files
By prabhakarlad in forum Software PlayingReplies: 13Last Post: 22nd Apr 2011, 14:55 -
Why video and audio out of sync while playing .mp4 and .mkv files?
By Bonie81 in forum Software PlayingReplies: 0Last Post: 6th Apr 2010, 18:03 -
Audio in MKV files goes out of sync when demuxed
By carlmart in forum Video ConversionReplies: 11Last Post: 29th Oct 2009, 06:18 -
StaxRip audio sync problem creating MKV files
By ejai in forum DVD RippingReplies: 0Last Post: 24th Apr 2009, 15:16
