Hello everyone,
How to convert AC3 True-HD to DTS (1510 Kbps) ?
Thx.
Results 1 to 16 of 16
You need a dts encoder. Those are not freeware and usually pretty expensive.
The bitrate you gave I am guessing you are trying to make it dvd compatible? You are better off using freeware like eac3to and downconvert to 448kbps ac3 so you can incorporate it properly into a dvd. You obviously won't have the same fidelity as the original audio but it will be a heck of a lot cheaper this way.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
The True-HD audio features original bitrate of 1800 Kbps. I would like to convert it to DTS 1510 Kbps to include it in a MKV video ripped from a Blu-ray.
I even convertible to AC3 640 Kbps, but the quality was much lower than the original, I believe in DTS 1510 Kbps would be much better.
Ps: Sorry for my bad English but I speak only Portuguese, I'm using the Google translator to write. -
If you don't care about file size why not leave the truehd in?
Going from 640 to 1510 dts will increase the file size.
Leaving the truehd intact would be the best way to go.
If you don't need to fit the mkv on a dual layer dvdr than size doesn't matter as long as you have the harddrive space for it.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I think, it should be done software automatically. Just try it. You have nothing to loose. It is question of time. If it is problem, I think that they will not supported it.
But on other hand I have not 6 wav channels to test it.
Bernix -
Then you may follow this one: https://trac.ffmpeg.org/wiki/AudioChannelManipulation#a5.16mono of course you can name it automatically using my example, side to this you may give a chance for ffmpeg to perform downmixing from 7.1 to 5.1 or even DTS or AC3 encoding.
Demuxing True-HD sound to convert to ac3
By out_sider in forum Blu-ray RippingReplies: 9Last Post: 28th Dec 2016, 19:33 -
How to convert AC3 to DTS
By lhockann in forum AudioReplies: 8Last Post: 3rd Jan 2012, 08:31 -
convert DTS from MKV to AC3
By cajmere in forum AudioReplies: 19Last Post: 9th Nov 2011, 22:04 -
cant convert true hd to dts 1536
By kevcampbell in forum AudioReplies: 3Last Post: 7th Sep 2009, 18:46 -
How to convert DTS audio to AC3?
By Henderson in forum AudioReplies: 1Last Post: 26th Jul 2007, 18:33
