I captured a tv show live online with a software.
The size of the videos are 160 mb and 35 mb.
When I try to convert them with XVID4PSP or any other
converter, I see that the output file size is like 200 gb.
These are the specs of one file:
appearently the stream size of video seems to be 120 GiB. how could it be possible?Complete name : C:\Users\Timur\Videos\TV2[1][1][1][1].asf
Format : Windows Media
File size : 35.3 MiB
Overall bit rate mode : Constant
Overall bit rate : 83 bps
Maximum Overall bit rate : 357 Kbps
Encoded date : UTC 2010-09-23 21:18:59.000
Video
Format : VC-1
Format profile : MP@ML
Codec ID : WMV3
Codec ID/Info : Windows Media Video 9
Codec ID/Hint : WMV3
Description of the codec : Windows Media Video 9
Bit rate mode : Constant
Bit rate : 291 Kbps
Width : 384 pixels
Height : 288 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.105
Stream size : 120 GiB
Language : English (US)
Audio
Format : WMA
Format version : Version 2
Codec ID : 161
Codec ID/Info : Windows Media Audio
Description of the codec : Windows Media Audio 9.2 - 48 kbps, 44 kHz, mono (A/V) 1-pass CBR
Bit rate : 48.0 Kbps
Channel(s) : 1 channel
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Stream size : 19.9 GiB
and is there a way that I can convert the video to a small mp4 size without problem?
i am desperately seeking help cuase its urgent
thanks
One thread is enough. I removed your other.
It might be corrupt. Try repair the the video with asfbin, add it and make a new asf. Try then convert with xvid4sps or xmedia recode. -
Please wait some days until you bump/reply to your thread. This is not a chat.
Try windows movie maker or windows media encoder and reconvert it and see how it works.
Looking for a hosting site to send or store a large size of .MTS video file
By coody in forum Video Streaming DownloadingReplies: 5Last Post: 25th Apr 2011, 17:08 -
Video stream size decreasing after deumxing?
By smackyourfupa in forum Video ConversionReplies: 4Last Post: 12th Mar 2011, 05:50 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 05:14 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 04:27 -
large file size when importing small video clips into Sonic MyDVD
By artistream in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2007, 20:48
