I have a lot of movie files on my X-ternal hard drive, and its already full, i would love to burn the movies onto dvd's and of course, delete them of my computer.
I have burned a few, and it seems like it works fine for a little, and then the movie just stops playing, freezes, then like 5 minutes later it plays another millisecond and so on and so forth.
I use Converttxtodvd program, all i really want is the movie, i dont care to much for anything fancy or extra cool things added, i just want to put the dvd in and watch. If there is a better program out there i would like to know.
I just dont want to waste any more of my money by burning dvds that dont work.
The Dvd's i was using are Memorax.
If there is like GB issues or other technical stuff, i am kind of a newbie at all this computer stuff, so if possible, i would love a little explanation of how to do anything really. lol
I know this is possible i have plenty of friends that make replicas of movies and burn little movies of the internet and them put them on dvds....ANY help would be greatly appreciated, and just amazing. Thanks any one........really, thanks!
				Results 1 to 11 of 11
	First suggestion is to try a different brand of blank dvds. Verbatim and taiyo yuden are generally recommended here. Also are you using imgburn to burn the dvds? That should be your default burning program. Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	Expensive ?
 http://www.newegg.com/Product/Product.aspx?Item=N82E16817507003
 Or you could keep using "MEMOREX" if you don't mind the way you report that they work.....
 What say's the type of file is not supported ?
 Imgburn just BURNS the disc, convertxtodvd converts xvid's to standard dvd format, but imgburn will burn xvids to dvd as xvid disc's so Imgburn is not saying the files are not supported, but your player must support xvid playback.
 But if the disc's are the problem, it won't matter a whole lot what you burn them with, and the only way i would use memorex dvdr's is if someone gave them to me and i wanted to use them to transfer files 1 time and throw them away
	Hey NoahTuck thanks for the input, no i dont care for the cost, they were like 60 bucks for 20, i dont mind the cost as long as they work.
 I was just kind of dumping them on the ImgBurn, but now i see what you mean, how do i get the converted file from Convertx to Imgburn?
 And as you can see i good wise sir, am a noob at this. lol
	If you factor in how many "I have burned a few, and it seems like it works fine for a little, and then the movie just stops playing, freezes, then like 5 minutes later it plays another millisecond and so on and so forth." the cheap discs are not so cheap anymore. Recommend Ty(JVC) and Verbs only. Try Rima.com or Supermediastore.com, get TY PREMIUM LINE ONLY discs, not the cheaper Valueline or you'll only have the same problems. +R 8x are generally accepted as the best single layer discs made, -R are still very good though. For DL discs, Verbs only, period. I love children, girl children... about 16-40
 W.C. Fields
	Ok So....these are the ones i should be getting right?: Taiyo Yuden JVC CD-R 80 Silver Lacquer////Taiyo Yuden DVD-R 4.7GB 16X Silver Lacquer,/////Taiyo Yuden JVC DVD-R 4.7GB 8X Silver Lacquer.
 Like i stated b4 i dont mind the prce i just want them to work. You are right Ricoman, the cheap ones come out expensive when they dont work at all.
	$60 for a 20 pack
 Yeah i don't know what you were looking at seeing as you can get a 50 pack of Dual Layers for $55.00!!
 Just yesterday i ordered 2 - 100packs of verbatim +R's from new egg for $18.99 each with free shipping.
 The one's i linked to,
 Plus they have combo deals where you can get a SATA or IDE dvd burner for as low as $12.00 per burner, for that price i bought 2 burners for extras.
 http://www.newegg.com/Product/ProductCombos.aspx?Item=N82E16817507003&SubCategory=71&S...Size=10&page=1
 Yeah i'm thinking so!!!
 Just set ConvertXtoDVD to output a VIDEO_TS folder instead of burning to disc, then load the VIDEO_TS folder into ImgBurn.
 But once again, if the media is crappy (see my previous comment on "MEMORSUX") it won't make much difference.
 W.C. Fields
	Why not just buy another external hard drive?
 Hard drives work out cheaper than DVD's, are much more reliable than DVD's, Take up less space.
  Resizing videos and creating multiple DVDs in batch?By DVD_Noob in forum Newbie / General discussionsReplies: 1Last Post: 8th Dec 2010, 02:40
  Problem copying DVDs to hard drive (previously copied from videos)By avz10 in forum RestorationReplies: 4Last Post: 2nd Mar 2010, 23:54
  Selling tangible DVDs as online videos?By sdsumike619 in forum Video Streaming DownloadingReplies: 6Last Post: 3rd Mar 2009, 15:14
  Anyone use a Multimedia hard drive to watch DVDs/videos on their TVBy Lothar1974 in forum Media Center PC / MediaCentersReplies: 1Last Post: 25th Oct 2007, 18:37
  Need help fixing up already converted DVDs of old videosBy t_burrito in forum RestorationReplies: 1Last Post: 10th Jun 2007, 01:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
