Digital TV broadcasting had been started in Japan in the form of HDTV. The only way to reord HDTV now is by D-VHS. Some of the D-VHS has i-link which enables DV-in but not DV-out. The i-link out is to another D-VHS. So, I suspect the existing capture cards and devices could not capture HDTV.
I want to capture HDTV out from D-VHS and then to make DVD-R with as highest quality as possible.
Do you have any ideas that I can adopt to achieve my goal?
Fred![]()
If it were up to me, I'd just use this card
http://www.reviewmakers.com/showdoc.php?review=25
or a region equivalent (U.S. NTSC would probably be the WinTV-D or WinTV-HD), encode to the compliant output. Fully digital process. -
Hi azali,
Thanks for your reply. But information at Hauppauge shows that WinTV-D aims at the digital systems in US or Europe. I don't know if it can receive digital broadcasting in Japan or not. Any ideas?
Fred -
I believe that Nova card from Hauppauge is for the Asian market. I believe that review was done from someone in Singapore. I'm not sure what format/standard Japan uses. I think it's a different form of NTSC (?). Hopefully someone else can provide some insight.
Do Samsung HDTV's have an RF antenna connector for receiving off-air HDTV?
By pianopeddler in forum DVB / IPTVReplies: 2Last Post: 6th Aug 2008, 21:43 -
Need al little help getting my new ati hdtv pci card to sense HDTV channels
By MidnightMike in forum ComputerReplies: 8Last Post: 23rd Jul 2008, 02:12 -
PC to HDTV
By carrspaints in forum ComputerReplies: 3Last Post: 7th Dec 2007, 18:53 -
Problems with connection with my Panasonic HDTV and Timewaner HDTV box...
By S4one in forum DVB / IPTVReplies: 7Last Post: 2nd Nov 2007, 22:39 -
Enigmavision HDTV - HDTV viewer software for ATSC TV tuner cards.
By gc04 in forum Latest Video NewsReplies: 9Last Post: 7th May 2007, 00:32
