I have this bluray movie in mkv format (not sure if you can still call it blu ray but the quality is).The size is 4 GB and I want to watch it on my DVD player.I tried converting it to VOB file using convertxtodvd but everytime I do it,it says memory overload or something like that.Any other way i can burn it on dvd without losing the HD quality?
I can't live without my computer.
A dvd player won't play HD video. You'll need to convert it to standard definition dvd-video if you want to play it on a regular dvd player. ConvertX should be able to do this, but if you want another program to try, AVStoDVD is free to use. Multiavchd can also output in standard def dvd-video.
You should post the error message from ConvertX. I'm sure the members here can provide some answers for you. -
Kerry56 is correct for a regular dvd player it will need to be reencoded - no way around that.
BUT if you have a bluray player why not encode it to avchd? Use multiavchd to take the mkv and output it to avchd. Assuming you have a bluray player that can play avchd than you are all set and you can easily burn it to regular dvdr with no problem at all (and you can use imgburn too
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
FWIW, I agree with both Kerry and Yoda on answer, software and method.
I love children, girl children... about 16-40
W.C. Fields
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
Can I use MKV Files to burn on Blu-Ray?
By PHNeedsHelp in forum Authoring (Blu-ray)Replies: 3Last Post: 22nd Mar 2012, 03:10 -
ripping/encoding a blu-ray with multiple .m2ts files
By badreligionhead in forum Blu-ray RippingReplies: 5Last Post: 4th Nov 2009, 21:37 -
Best way to convert/burn/play .mkv H.264 Blu-ray/HD DVD files on a Mac
By iMacMan in forum MacReplies: 7Last Post: 21st Mar 2009, 17:50 -
xvid4psp, encoding settings suggestions please, blu-ray-> blu-ray
By runLoganrun in forum Video ConversionReplies: 4Last Post: 16th Jan 2009, 09:07
