I have a copy of MyDVD, which I believe is more or less the same as DVDit!. It will accept mpeg-1 and mpeg-2 video files, but it will not burn mpeg-1 layer 2 audio, which is the default audio compression format for all mpeg files. For some stupid reason, MyDVD uncompresses the audio to PCM audio, and waste a *HUGE* amount of space on the DVD. Every DVD player can decode mpeg-1 layer 2 audio, so why is MyDVD converting all audio to uncompressed PCM? I know that the NTSC DVD "spec" calls for one PCM audio stream, whatever that is good for, but this is not the case for PAL DVD's. So, I want to burn a DVD with no PCM audio on the disk, only mpeg-1 layer 2 audio. Is there any authoring software out there that will burn true mpeg files without messing with the audio? I do not want any PCM audio on the DVD.
Results 1 to 9 of 9
Hi there,
MyDVD is not the same as DVDit!. I got MyDVD with my Philips DVD+RW 208, but I didn't even tried it, because MyDVD is a piece of crap (that's what I heard.)
You need to try SpruceUP or Maestro. In SpruceUP you can load multiplexed MPEG-2 file with MPEG audio track. In Maestro you need to load them as seperate files.
Also if you load multiplexed file in DVDit!, it will burn it. I was able to di it once (I may be wrong).
Regards. -
Don't know if this helps but, DVDit PE will compress audio to Dobly digital or PCM.... your choice.
Thanks for the info!
I also read that Ulead DVD movie factory should be able to burn mp2 audio directly without converting to PCM. Also, I'm hoping Nero will add a simple template for burning multiplexed mpeg files to a DVD.
To make a DVD usefull for VHS transfers, it should be able to handle 4 hours of 352x480 mpeg-2 video and audio, or 5 hours of mpeg-1 352x240 files. I can easily play those files on a CD-R, so I see no reason why it shouldn't work on a DVD-R! -
Originally Posted by skittelsen
PCM = huge waste of space, uncompressed audio, no thanks.
Dolby digial = recompression, takes time.
The captured audio and video from most mpeg devices have the audio already compressed as mpeg-1 layer 2, a perfectly fine format for every DVD player. Why waste space by converting to PCM, or waste time converting to Dolby Digital? -
Thanks everybody!
A copy of Ulead Moviefactory is less than $50, a good price, and it will do what I want to. Still, I have a copy of MyDVD that will get no use... -
Funny!
MyDVD will accept mpeg-1 video with a bit rate from 1150 to 1856Kb/sec. but will not accept mpeg-1 layer 2 audio. DVD factory will allow mpeg-1 layer 2 audio but no mpeg-1 video! What are all these people smoking?
I hope Nero comes out with a simple template that will burn any mpeg file to a DVD, and then let the DVD player figure out what it can play... then all the so called DVD authoring software makers can take a hike :)
dvd authoring software
By devdev in forum MacReplies: 2Last Post: 20th Apr 2012, 04:36 -
I need new Dvd Authoring software ?
By mrjust in forum Newbie / General discussionsReplies: 10Last Post: 28th Mar 2010, 17:13 -
DVD Authoring Software
By Toxic1 in forum Authoring (DVD)Replies: 5Last Post: 21st Feb 2010, 02:39 -
By rancineb in forum Authoring (DVD)Replies: 8Last Post: 9th Jul 2008, 14:11 -
Best DVD authoring software?
By skybadger in forum Authoring (DVD)Replies: 8Last Post: 16th Aug 2007, 05:11
