I started getting this message randomly very recently. I updated to the latest software. It did not help. Does anyone have any ideas?
Version: VOB2MPG PRO
Build: 3.0.0710
Type: System.ArgumentOutOfRangeException
Source: mscorlib
Message: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
InnerException:
StackTrace: at System.Collections.CollectionBase.System.Collectio ns.IList.get_Item(Int32 index)
at VOB2MPG_PRO.IFO.xe2e75cd0c88496d4.get_Item(Int32 index)
at VOB2MPG_PRO.IFO.x32eac27632acc346.xc5034730a302ffc e()
at VOB2MPG_PRO.IFO.x32eac27632acc346.xa3a9daebe1fd5c9 3(String xeadccf02f8622700, Boolean xb909d68cec5e9c0b)
at VOB2MPG_PRO.xfed3de3bc2a8e64d.bOpen_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at DevComponents.DotNetBar.ButtonX.OnClick(EventArgs e)
at DevComponents.DotNetBar.ButtonX.OnMouseUp(MouseEve ntArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at DevComponents.DotNetBar.PopupItemControl.WndProc(M essage& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
I just got the same error:
Build: 3.0.0820
Source: mscorlib
InnerException:
Not sure what it might be. This is the first time I've seen it.
Kevin -
If you can zip up and post all the *.IFO files for the DVD i will investigate.
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 21:18 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41 -
Error Message
By Perfik in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Jul 2007, 13:45 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 02:16 -
Error Message
By Kallid in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 15th Jun 2007, 21:13
