Using Vegas 9e (both 32 and 64) on Win7-64 system. After importing a number of DV clips onto the timleine, I export to a single DV clip for use with VirtualDub (very fast--no recompress). I then open the clip in VirtualDub, apply some noise reduction filters, and then save as a new DV clip using the MainConcept DV codec. However, Vegas doesn't seem to like the new clips. When I "click" on one of these files in the explorer window, Vegas hangs indicating the the software is not responding, but after a minute or so it eventually identifies the file and lets me drag it to the timeline. While not a complete showstopper, it is very annoying. Once on the timeline, I can re-render to another DV file (no recompress) and at that point, it will quickly be identified. Perhaps Vegas doesn't like the MainConcept DV codec? Any suggestions would be greatly appreciated. Thanks in advance.
wwaag
	This is normal, Vegas needs time to ingest the media.
 Why not use the Sony filter(s)? Use track FX in the lefthand panel to do all the events with the same filter.
 There are many good reasons to go outside Vegas, but this isn't one of them  Last edited by budwzr; 10th Oct 2010 at 01:22.
	I've tried Cedocida with the same result.
 I've just downloaded the new Vegas Pro10. Same thing--it takes a very long time to ingest these DV files. Here's what's odd--if I open them in Vegas Pro 8c, they ingest almost instantly. If I re-render them to DV (no recompress), they will load "almost instantly" in V9 and V10. Any ideas?
 I've been using some of the noise reduction filters not available in Vegas, including Neat Video--hence the reason to go outside of Vegas.
 Thanks for the replies.
 wwaag
	The thing is, don't view this as a negative. The power in the Vegas timeline is awesome and unmatched by any other NLE. You can throw all kinds of mixed media on the same track and edit transparently without a care for formats and codecs etc. That "magic" timeline is what you're paying for, and is the core functionality that makes Vegas what it is. So think positive
  x264vfw, virtualdub and vegas?By greatveemon in forum Newbie / General discussionsReplies: 5Last Post: 16th Jan 2011, 09:32
  Virtualdub framesever to Sony VegasBy jairovital in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jul 2010, 12:00
  VirtualDub to sony vegas problems HELPBy iTzRingoBrown in forum Capturing and VCRReplies: 3Last Post: 2nd Jul 2010, 12:08
  VirtualDub to sony vegas problem HELPBy iTzRingoBrown in forum Newbie / General discussionsReplies: 1Last Post: 1st Jul 2010, 21:50
  import VirtualDub filters into Vegas?By Srivas in forum EditingReplies: 8Last Post: 8th Oct 2008, 06:49
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
