Ok guys so I am new to AviSynth.I downloaded a script for video enhancing and I have a problem with it.The path of the video is not specified and I don't know where/how to add it.
I would be appreciate your responses.Thank you very much!
The code:
#REMOVE DIRT FUNCTION
function RemoveDirt(clip input, int limit, bool _grey)
clensed=input.Clense(grey=_grey, cache=4)
alt=input.RemoveGrain(2)
return RestoreMotionBlocks(clensed,input,alternative=alt, pthreshold=6,cthreshold=8, gmthreshold=40,dist=3, dmode=2,debug=false,noise=limit,noisy=4, grey=_grey)
# Alternative settings
# return RestoreMotionBlocks(clensed,input,alternative=alt, pthreshold=4,cthreshold=6, gmthreshold=40,dist=1,dmode=2,debug=false,noise=li mit,noisy=12,grey=_grey,show=true)
# return RestoreMotionBlocks(clensed,input,alternative=alt, pthreshold=6,cthreshold=8, gmthreshold=40,dist=3,tolerance= 12,dmode=2,debug=false,noise=limit,noisy=12,grey=_ grey,show=false)
function RemoveDirtMC(clip,int limit, bool "_grey")
_grey=default(_grey, false)
limit = default(limit,6)
i=MSuper(clip,pel=2)
bvec = MAnalyse(i,isb=false, blksize=8, delta=1, truemotion=true)
fvec = MAnalyse(i,isb=true, blksize=8, delta=1, truemotion=true)
backw = MFlow(clip,i,bvec)
forw = MFlow(clip,i,fvec)
clp=interleave(backw,clip,forw)
clp=clp.RemoveDirt(limit,_grey)
clp=clp.SelectEvery(3,1)
return clip
Results 1 to 24 of 24
What format is your video? You need a source filter to load the video
e.g.
AVISource("PATH\video.avi")
#some filter
you don't need to specify the "PATH" if the .avs script is in the same directory as the video
you might want to have a look at the basic tutorials for getting started
http://avisynth.org/mediawiki/Main_Page
http://avisynth.org/mediawiki/First_script
http://avisynth.org/mediawiki/Getting_started -
thank you.the video is ".avi",virtual dub (not mod) accepts only avi.
when i try to load the script it says "the script's return value is not a videoclip"....
post your exact script . The "PATH" should be replaced by the actual directory path C:\folder\etc , wherever your file is located. If it's in same directory as video, then you can omit it. Change the filenames to match
AVISource("video.avi") -
AVISource("D:\video.avi")
return clip
Your video is called "video.avi?" and it's in the D directory ?
You also need to use the filter, you have only listed the function but haven't called it
e.g.
AVISource("somevideo.avi")
RemoveDirtMC(10,false) -
yep.
I see.but i want to use the whole script.how can I specifiy a filter -
I can open the video in virtual dub.i can open it in sony vegas,mediainfo,everything.
When I open it with the specified path it says:
"AVI Source: couldn't locate a decompressor four fourcc dvsc" -
Hey.I got another problem with the scripts.the original one was meant to make a comparision between videos and I wanted to know if it's possible to delete it.
Script:
# film restoration script by videoFred.
# modified 30 august 2010
# version with frame blending
# added removedirtMC() as suggested by John Meyer
# cleaning, degraining, resizing, stabilizing, sharpening, auto-levels and auto-white balance.
film="D:\03_RemoveDirtMC.avi" # source clip, please specify the full path here
#PARAMETERS
result="resultS3" # specify the wanted output here
trim_begin=2 play_speed= 18.75 #trim frames and play speed (PAL: 16.6666 or 18.75)
final_framerate = 25 # final frame rate
#COLOR AND LEVELS PARAMATERS
saturation=1.4 #for all outputs
gamma= 1.0 # for all outputs
blue= -0 red= 0 #manual color adjustment, when returning result3 or result4. Values can be positive or negative
black_level=0 white_level=255 output_black=0 output_white=255 # manual levels, when returning result4
#SIZE, CROP AND BORDERS PARAMETERS
CLeft=20 CTop=20 CRight=20 CBottom=20 #crop values after Depan and before final resizing
W=720 H=576 #final size after cropping
bord_left=0 bord_top=0 bord_right=0 bord_bot=0 #720p= borders 150
#STABILISING PARAMETERS
maxstabH=20
maxstabV=20 #maximum values for the stabiliser (in pixels) 20 is a good start value
est_left=40 est_top=40 est_right=40 est_bottom=40 est_cont=1.4 #crop and contast values for special Estimate clip
#CLEANING PARAMETERS
dirt_blur= 0.1 # some blur before cleaning to avoid pixel artifacts
dirt_strength=40 # set this lower for clean films.
#DENOISING PARAMETERS
denoising_strength= 800 #denoising level of second denoiser: MVDegrainMulti()
denoising_frames= 4 #number of frames for averaging (forwards and backwards) 3 is a good start value
block_size= 16 #block size of MVDegrainMulti()
block_size_v= 16
block_over= 8 #block overlapping of MVDegrainMulti()
# FOUR STEP SHARPENING PARAMETERS
USM_sharp_ness1= 120 USM_radi_us1= 3 #first sharpening (UnsharpMask) after cleaning with removedirtMC()
USM_sharp_ness2= 80 USM_radi_us2=2 #second harpening (UnsharpMask) after cleaning with removedirtMC()
USM_sharp_ness3= 70 USM_radi_us3=1 #third sharpening (UnsharpMask) after degraining with MVDegrainMulti()
last_sharp= 0.4 #final sharpening step after interpolation
last_blur= 0.2 #this smooths out the heavy sharpening effects
#AUTO LEVELS PARAMETER
X=2 # X is a special parameter for reducing the autolevels effect on the whites
X2=2 # X2 is a special parameter for reducing the autolevels effect on the blacks
# END VARIABLES, BEGIN SCRIPT
SetMemoryMax(800) #set this to 1/3 of the available memory
SetMTMode(5) #disable all MT calls if you are using a single core computer
LoadPlugin("Deflicker.dll")
Loadplugin("Depan.dll")
LoadPlugin("DepanEstimate.dll")
Loadplugin("removegrain.dll")
LoadPlugin("removedirt.dll")
LoadPlugin("MVTools.dll")
LoadPlugin("MVTools2.dll")
Loadplugin("mt_masktools.dll")
Loadplugin("warpsharp.dll")
LoadPlugin("MT.dll")
LoadPlugin("autolevels.dll")
Import("03_RemoveDirtMC.avs")
source1= AviSource(film).assumefps(play_speed).trim(trim_be gin,0).converttoYV12()
SetMTMode(1,0)
#STABILIZING/CROPPING
stab_reference= source1.crop(est_left,est_top,-est_right,-est_bottom).tweak(cont=est_cont).MT_binarize(thres hold=80).greyscale().invert()
mdata=DePanEstimate(stab_reference,trust=1.0,dxmax =maxstabH,dymax=maxstabV)
stab=DePanStabilize(source1,data=mdata,cutoff=0.5, dxmax=maxstabH,dymax=maxstabV,method=0,mirror=15). deflicker()
stab2= stab.crop(CLeft,CTop,-CRight,-CBottom)
stab3=DePanStabilize(source1,data=mdata,cutoff=0.5 ,dxmax=maxstabH,dymax=maxstabV,method=0,info=true)
WS= width(stab)
HS= height(stab)
stab4= stab3.addborders(10,10,10,10,$B1B1B1).Lanczos4Resi ze(WS,HS)
stab5= Lanczos4Resize(stab2,W,H).sharpen(0.5)
#CLEANING/PRESHARPENING/RESIZING
noise_baseclip= stab2.levels(0,gamma,255,0,255).tweak(sat=saturati on).blur(dirt_blur)
cleaned= RemoveDirtMC(noise_baseclip,dirt_strength).unsharp mask(USM_sharp_ness1,USM_radi_us1,0)\
.unsharpmask(USM_sharp_ness2,USM_radi_us2,0).Lancz os4Resize(W,H)
#DEGRAINING/SHARPENING
vectors= cleaned.MVAnalyseMulti(refframes=denoising_frames, pel=2, blksize=block_size, blksizev= block_size_v, overlap=block_over, idx=1)
denoised= cleaned.MVDegrainMulti(vectors, thSAD=denoising_strength, SadMode=1, idx=2).unsharpmask(USM_sharp_ness3,USM_radi_us3,0) \
.sharpen(last_sharp).sharpen(last_sharp)
#RESULT1: AUTOLEVELS,AUTOWHITE
result1= denoised.coloryuv(autowhite=true).addborders(X,0,0 ,0,$FFFFFF).addborders(0,0,X2,0,$000000).autolevel s().crop(X,0,-X2,-0)\
.converttoYUY2().ConvertFPS(final_framerate).blur( last_blur).converttoYV12().addborders(bord_left, bord_top, bord_right, bord_bot)
#RESULT2: MANUAL LEVELS, AUTOWHITE
result2= denoised.levels(black_level,1.0,white_level,0,255) .coloryuv(autowhite=true)\
#RESULT3: AUTOLEVELS, MANUAL COLOR CORRECTIONS
result3= denoised.coloryuv(off_U=blue,off_V=red).addborders (X,0,0,0,$FFFFFF).addborders(0,0,X2,0,$000000).aut olevels().crop(X,0,-X2,-0)\
#RESULT4: MANUAL LEVELS, MANUAL COLOR CORRECTIONS
result4= denoised.coloryuv(off_U=blue,off_V=red).levels(bla ck_level,1.0,white_level,0,255)\
#RESULT5: SPECIAL SERVICE CLIP FOR RESULT S5
result5= overlay(source1,stab_reference,x=est_left,y=est_to p).addborders(2,2,2,2,$FFFFFF).Lanczos4Resize(WS,H S)
#PARAMETERS FOR THE COMPARISONS
W2= W+bord_left+bord_right
H2= H+bord_top+bord_bot
source4=Lanczos4Resize(source1,W2,H2).changeFPS(fi nal_framerate)
#COMPARISONS: ORIGINAL VS RESULTS
resultS1= stackhorizontal(subtitle(source4,"original",size=2 8,align=2),subtitle(result1,"result1: autolevels, autowhite",size=28,align=2))
resultS2= stackhorizontal(subtitle(source4,"original",size=2 8,align=2),subtitle(result2,"resuls2: autowhite, manual levels correction",size=28,align=2))
resultS3= stackhorizontal(subtitle(source4,"original",size=2 8,align=2),subtitle(result3,"result3: autolevels, manual color correction",size=28,align=2))
resultS4= stackhorizontal(subtitle(source4,"original",size=2 8,align=2),subtitle(result4,"result4: manual colors and levels correction",size=28,align=2))
#SPECIAL COMPARISON CLIP FOR TESTING THE STABILIZER
resultS5= stackhorizontal(subtitle(result5,"baseclip for stabiliser -only the B/W clip is used",size=32,align=2),subtitle(stab4,"test stabiliser: dx=horizontal, dy=vertical",size=32,align=5))
SetMTMode(5)
Eval(result) -
Script:
#PARAMETERS
maxstabH=20
block_size_v= 16
SetMTMode(1,0)
WS= width(stab)
HS= height(stab)
SetMTMode(5)
Eval(result)Last edited by Dr.Who; 9th Oct 2010 at 14:04.
Change the line
toCode:result="resultS3" # specify the wanted output here
That line specifies which of the various results you want the script to produce.Code:result="result3" # specify the wanted output here
See the script for what the different results are, eg
By adding 'S' in the name, eg resultS3, you get a comparison with the original.Code:#RESULT3: AUTOLEVELS, MANUAL COLOR CORRECTIONS
thank you!
edit: it says avisynth autodetect: couldn't open file error code 2...Last edited by Dr.Who; 9th Oct 2010 at 05:54.
replace that line with your filename with full pathfilm="D:\03_RemoveDirtMC.avi" # source clip, please specify the full path here
You have to modify a lot of the script for your specific source - videofred's script is for 8mm film transfer and the frame rate will be incorrect -
The script you posted has many space characters in the middle of names and numbers. Are those actually in the script or is it just the post that's messed up? For example, near the end is the line:
There's a space between the 2 and 8 of what should read "size=28". And in:resultS1= stackhorizontal(subtitle(source4,"original",size=2 8,align=2)...
There a space between the a and c of what should read "black_level".result4= denoised.coloryuv(off_U=blue,off_V=red).levels(bla ck_level,1.0,white_level,0,255)\
All the loadplugin() lines need the full path to the files. -
@poisondeathray - that's the filename with the full path
@jagabo it's because of the page. -
Yeah that's the name.This is the personalised version of the script.
This is the original version:
# version with frame interpolation
film="K:\02-dodcaps\PDS\1967\pds_1967.04.avi" # source clip, please specify the full path here
#PARAMETERS
trim_begin=2 play_speed=18.75 #trim frames and play speed (PAL: 16.6666 or 18.75)
numerator= 25 #numerator for the interpolator (final frame rate)
denumerator= 1 #denumerator example: 60000/1001= 59.94fps
saturation=1.2 #for all outputs
blue= -0 red= -0 #manual color adjustment, when returning result3 or result4. Values can be positive or negative
maxstabH=20
denoising_strength= 900 #denoising level of second denoiser: MVDegrainMulti()
denoising_frames= 3 #number of frames for averaging (forwards and backwards) 3 is a good start value
block_size_v= 16
SetMTMode(1,0)
WS= width(stab)
HS= height(stab)
#CHANGING FRAME RATE WITH INTERPOLATION/FINALSHARPENING
super= denoised.MSuper()
backward_vec= MAnalyse(super, blksize=block_size, blksizev= block_size_v, overlap=block_over, isb=true)
forward_vec= MAnalyse(super,blksize=block_size, blksizev= block_size_v, overlap=block_over, isb= false)
interpolated= denoised.MFlowFps(super, backward_vec, forward_vec, num=numerator, den= denumerator, ml=100)\
.sharpen(last_sharp).sharpen(last_sharp).blur(last _blur)
result1= interpolated.coloryuv(autowhite=true).addborders(X ,0,0,0,$FFFFFF).addborders(0,0,X2,0,$000000)\
.autolevels().crop(X,0,-X2,-0).addborders(bord_left, bord_top, bord_right, bord_bot)
result2= interpolated.levels(black_level,1.0,white_level,0, 255).coloryuv(autowhite=true)\
result3= interpolated.coloryuv(off_U=blue,off_V=red).addbor ders(X,0,0,0,$FFFFFF)\
.addborders(0,0,X2,0,$000000).autolevels().crop(X, 0,-X2,-0).addborders(bord_left, bord_top, bord_right, bord_bot)
result4= interpolated.coloryuv(off_U=blue,off_V=red).levels (black_level,1.0,white_level,0,255)\
final_framerate= numerator/denumerator
resultS2= stackhorizontal(subtitle(source4,"original",size=2 8,align=2),subtitle(result2,"result2: autowhite, manual levels correction",size=28,align=2))
resultS5= stackhorizontal(subtitle(result5,"baseclip for stabiliser -only the B/W clip is used",size=32,align=2),\
SetMTMode(5)
Eval(result) -
#PARAMETERS
maxstabH=20
block_size_v= 16
SetMTMode(1,0)
WS= width(stab)
HS= height(stab)
SetMTMode(5)
Eval(result)
Error: The source image format is not acceptable (error code -2)
By Russo in forum DVD RippingReplies: 3Last Post: 5th Jul 2011, 10:50 -
Opening Avisynth script on virtualDub - Error Message
By HugoBraule in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2010, 21:48 -
Avisynth code...
By bsuska in forum Video ConversionReplies: 5Last Post: 16th Jul 2009, 12:09 -
creating flv’s using avisynth code
By lindylex in forum EditingReplies: 0Last Post: 5th Jul 2008, 13:09 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
