Hello
I have an ISO of Alice in Wonderland and I'm having a hard time to get it working on my PC.
It worked in VLC but I'm only getting PCM audio through my receiver, trying to gett DTSHD.
I tried mounting it and using powderDVD but it said it can't play the format?
I tried makemkv but I was getting errors with that too.
What other options are there?
Thanks.
Have you tried mount with dvdfab virtual drive and play with powerdvd?
Or try TMT3. -
I mounted with Daemon tools. I'm getting the newer version of PowerDVD so I'll try that. I think the one I had maybe couldn't play certain Bluray? I read something that you need the "Ultra" version. We'll see. If not, I'll try that. Thanks.
dvdfab virtual drive claims that it works better with powerdvd.
I'll try that. PowerDVD 10 Ultra gave same error. Thanks.
** That worked, thank you. Still only getting PCM audio and not TrueHD, but that probably has to do with my receiver and not the program, as the program says TrueHD audio.
Thanks again.Last edited by doogie88; 8th Oct 2010 at 14:37.
ISO best wireless keyboard for an htpc
By Haopengyou in forum Media Center PC / MediaCentersReplies: 6Last Post: 15th Sep 2011, 11:27 -
HTPC problems with HDMI audio
By moviewatcher666 in forum Media Center PC / MediaCentersReplies: 5Last Post: 9th Feb 2011, 12:51 -
playing an iso file
By ronens in forum Newbie / General discussionsReplies: 0Last Post: 4th Jan 2009, 22:29 -
Problems Playing Bluray ISO in PowerDVD 8
By aye29 in forum Software PlayingReplies: 5Last Post: 4th Sep 2008, 20:28 -
HTPC ...playing episodes from DVD images
By lordhutt in forum ComputerReplies: 7Last Post: 10th Jan 2008, 11:32
