Im having an issue with the current version of MakeMKV. Some of my dvd rips fail to be processed and ive narrowed it down to the audio stream. If i uncheck the audio, then it will go through and make the mkv of the video.
What I was wondering is if anyone had access to older versions of this. The dev's forums werent any help and I havent found any sources for anything other than 1.6.0. If anyone knows where i can find older versions, that would be great. Or if there is an alternative program that will do this, ill try that too.
Thanks.
Varsion 1.44 is avail from the tools section on this site
tony -
This site has a copy of one older version available - https://www.videohelp.com/tools/MakeMKV/old-versions#download
Edit Baldrick: Actually all versions, https://www.videohelp.com/tools/MakeMKV/old-versions#download . Just a bug in the tools listLast edited by Baldrick; 8th Oct 2010 at 07:06.
Read my blog here.
yeah i did forget to mention that one. i tried it, but the wierd thing is that when i try to run it, it tells me that the demo is too old and that i should download the latest, then the app closes. so i dont know why its doing that, but its useless otherwise.
Actually, it is pretty common for beta software. As beta software often contains bugs, users are encouraged to keep up with releases where these bugs are often fixed. Of course one of the joys fo beta software is that for every two bugs squashed in a given release, the chances are high there will be a new added in return
You say that only some of your rips fail to process - what is it that is common with these rips - same audio format ?
How are you ripping the discs ?Read my blog here.
the common issue seems to be the audio. its only happening with two dvd rips so far. i guess the hard way around this would be to just process the subs and video in one mkv and then us another app to extract the audio and then mux that into the mkv i created out of the video and subs.
ive been trying to use pgcdemux to pull the audio stream, but im having trouble figuring out how to use it at the moment lol.
makemkv
By maxone71 in forum Blu-ray RippingReplies: 2Last Post: 5th Feb 2011, 07:55 -
Trying to use MakeMKV
By Humbug in forum Blu-ray RippingReplies: 4Last Post: 7th Nov 2010, 10:14 -
MakeMkv help
By razl in forum Newbie / General discussionsReplies: 0Last Post: 29th Jun 2010, 23:35 -
MakeMKV
By magmo in forum DVD RippingReplies: 1Last Post: 10th Nov 2009, 13:59 -
Using MakeMKV
By johnc10 in forum SubtitleReplies: 0Last Post: 6th Jun 2009, 07:52
