Goodday everybody,
I would like to know if it's possible to get your DTS sound from the DVD to your VCD. Till know all the vcd's I've copied are PCM.
Does anybody has any information for me, Thanhssxxx
BARCELONA
well vcd ( and svcd ) standards dont allow for anything but pcm/wav ( officaly , but i do belive it is possable on some dvd players to use a multitrack mpeg audio track ) so the normal method is ac3 -> wav -> mp2 ... as for DTS ... i dont know how to get a DTS track on a DVD let alone a vcd ... ( ya i know their has to be some software out their but i have yet to here of it ) .... so the best i know of currently is to find somthing to break the DTS into 6 wav's then down mix it .... look around at some of the audio tools and their home sites .. maby someone knows of a program that works with dts
Pinnacle Impression Pro handles ac3 and 16:9 screen ratio. I think some products from Sonic Foundry also handle ac3.
you can put dts on a vcd, but only on menus. it has to be 44.1khz. this is because vcd supports cdda tracks, so u can make dts-cd type tracks which can be decoded by your receiver.
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 21:24 -
Convert DTS-MA to DTS with XMedia Recode?
By smackyourfupa in forum Blu-ray RippingReplies: 3Last Post: 14th Apr 2011, 08:23 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10 -
DTS encoded disk, output to DTS receiver using an HTPC
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 18th Nov 2007, 07:06
