The past 3 versions or so of Xmedia Recode seem to be crashing on me when converting files to MKV. My Bad, as I don't recall which was the last version I had that worked and I've been lazy about posting this.
I have tried both of the latest install version and the portable version - 2.2.7.7
Here are the details of the crash:
Problem signature:
Problem Event Name: APPCRASH
Application Name: XMedia Recode.exe
Application Version: 2.2.7.7
Application Timestamp: 4ca89814
Fault Module Name: libx264.dll
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 4ca87294
Exception Code: c0000005
Exception Offset: 0005b2db
OS Version: 6.1.7600.2.0.0.768.3
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Any one have a similar issue and better yet, a solution?
Thanks.
--dES
PS. I've also sent a message to the author, will post the response.
"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com -
Haven't heard back from the author, but I had time tonight to experiment with different builds from his archives. Seems 2.2.4.4 is the most stable one on my system. Guess that will have to do for now.
--dES"You can observe a lot by watching." - Yogi Bera
Hi,
have the same problem. Using the x264-Codec always causes a crash with the "libx264.dll".
And yes, v.2.2.4.4 is the newest version which causes no crash - I use the same version.
I have heard updating the ffdshow would help, haven't tried it until now.
Does anyone have an idea for our problem?Last edited by bugmen0t; 16th Oct 2010 at 19:51.
The same problem occurs to me. I am using v.2.2.9.3 Portable.
I'll try to encode x264 into an AVI conteiner and let you know the results. If anyone, by the way, suceeds in encoding x264 to mkv with this app (Xmedia Recode), please let me know.
Thank you.Last edited by mauriciocamara; 12th Dec 2010 at 14:58. Reason: Adittional information.
Ok, I've done several and several tests with the portable and the installable versions (v2.2.9.3).
Looks like MKV container is still somehow buggy, I guess.
Otherwise, I've noticed that the program rarely considers my chosen video bitrate. When I try to encode a backed-up DVD to 1500kbps, usually the results come between 450 and 750kbps - regardless of the codec chosen (I've tried Xvid, MP4 and MP4/AVC) and its configuration (Trellis, B-Frames, etc).
Anyone got a hint?
Xmedia Recode help!
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2012, 11:36 -
Xmedia Recode not converting
By maxrockpro in forum Video ConversionReplies: 4Last Post: 31st Oct 2011, 10:52 -
XMedia Recode v 2.2.1.6
By Bonie81 in forum Video ConversionReplies: 2Last Post: 4th Jun 2011, 14:19 -
Xmedia Recode V. 2.25.8
By pepegot1 in forum Video ConversionReplies: 20Last Post: 29th Aug 2010, 23:58 -
XMedia Recode v2.2.2.0 DVD->MKV (H264AVC+AC3) Ms Visual C++ Runtime Error
By Bonie81 in forum DVD RippingReplies: 2Last Post: 13th May 2010, 11:32
