I need help to edit video in Pro Res over Windows using Premier Pro2.
Is there anyone who can help?
Thanks!
I'm not sure if it will work for PP2, but for PP CS3/4/5 you install quicktime and the windows prores decoder
http://support.apple.com/downloads/Apple_ProRes_QuickTime_Decoder_1_0_for_Windows
The latest few versions of quicktime have a bug, so most people use earlier versions (like 7.4.x) -
Thanks Poison,
Did it all but still doesn't work.
I'm kind in a hurry to edit this video.
Thanks -
Then you need a mac , or upgrade your premiere pro . It might be incompatibility with older versions, because it works on newer versions of PP
You could use QTSource and avisynth to convert it to something else (like uncompressed AVI)
Can't edit video file converted from DVD to AVI in Adobe Premier
By GalMed in forum EditingReplies: 12Last Post: 24th Feb 2012, 13:53 -
Blurry video in monitor of Premier Pro CS5
By oldtimefiddler in forum Newbie / General discussionsReplies: 10Last Post: 21st Jan 2012, 00:25 -
Blurry video. How do I change video quality on premier pro? Thank you..
By nfreytes in forum Newbie / General discussionsReplies: 27Last Post: 7th May 2009, 23:24 -
Dropped frames when importing Windows Movie Maker video into Magix edit pro
By gom in forum EditingReplies: 1Last Post: 27th Oct 2008, 10:55 -
Premier Pro Video Import Problem
By JojoTilly in forum Video ConversionReplies: 0Last Post: 3rd Jun 2008, 17:42
