Anyone know why i cant export from Adobe After Effects CS5 with x246vfw codec like in CS4? the only h264 codec is the main concept. Im pretty sure i have x264vfw codec installed amongst all the other codecs i was using, they are just not available in the drop menu for exporting anymore.
Ive used both programs CS4 and CS5 on the same 64bit Windows 7.
Please advise.
So anyone know how can i make AE CS5 to export with all the video codecs i have installed on my system, not only those main concept ones?
you need 64-bit versions of those video codecs , otherwise CS5 won't "see" them
is there anyway to export from Adobe After Effects CS5 to H.264? or other?
By Onceler2 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2011, 15:59 -
Premire Pro CS5 Export does not work with iPhone Anymore
By bowmah in forum Newbie / General discussionsReplies: 0Last Post: 8th Mar 2011, 16:38 -
Xvid 64bit and CS5 export
By fazzioo in forum Newbie / General discussionsReplies: 3Last Post: 6th Feb 2011, 12:20 -
Premiere Pro CS5 Green Bar, Smooth Playback, Choppy Export
By bowmah in forum Newbie / General discussionsReplies: 10Last Post: 27th Jan 2011, 22:38 -
Export Multi Audio using Premier Pro CS5. How ?!
By SB4 in forum EditingReplies: 16Last Post: 21st Nov 2010, 03:08
