  1. My first time ever in having a problem; here is the error message I'm getting
    Version: SVCD2DVD 2.5
    Build: 2.5.5030.0
    Type: System.AccessViolationException
    Source: SVCD2DVD
    Message: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
    InnerException:
    StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.AuthorDVD(xc76 139390a97debb xd2637df501625a82, x81974c36d7fdf1e1 xb4ee5c1758e9e983, Int32 xdc4f66b5011a3c9d, String[] x738d70b20493db82, Boolean x6b20cb17e8070d92, Boolean x3c21da9f928aac10)
    at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
    at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
    at x3284ccece41ee22b.xd3764d4f1e921081.x12cbe7a4e46ac 9ae()
    at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
    at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
    at System.Threading.ThreadHelper.ThreadStart()
    Had tried rebooting my system to see if it freed up memory but the same error message. The error happens as it starts to create the Titleset. I'm running W7 and have 4 gigs of ram with plenty of HD space available.
    Any advise
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can you post your log file for this run please?
    USA
    Check the name you are using for the file and make sure there are no odd characters or spaces in it.
    Check the locations that SVCD2DVD is storing the output file and using for temp files. If nothing unusual, I'd try uninstalling, then reinstalling SVCD2DVD.
    The program seems to be trying to use a RAM address that's incorrect. It's possible you have some sort of registry corruption and that may reset it.
    If you get the same problem again, you might want to try a RAM testing program like Memtest 86 just to rule out failed RAM as the problem.
    EDIT: But I would do what Chrissyboy suggests first.
  4. Thanks for taking the time to respond. Before posting the log, just to let you know, I had ran another conversion to DVD with another file and it had worked fine. So I think it is the file that may be the problem. I am able to view the movie using Nero and with the Windows media player. By the way I had also tried renaming the MP4 extension to an avi extension but it had crashed at the same point.
    The log is over 14mb so I show the first part and the end. the middle part repeats itself many, many times
    Title: 2.5
    Version: 2.5.5030.0
    Executable: D:\BadgerIT\SVCD2DVD v2.5\SVCD2DVD.exe
    Executable size: 2.58 MB
    Executable size in bytes: 2711635
    Executable CreationTime: 1/28/2009 9:57:36 PM
    Executable LastWriteTime: 2/16/2010 10:27:56 PM
    Executable LastAccessTime: 2/16/2010 10:27:56 PM
    ************************* Operating System *************************
    Operating System: Microsoft Windows 7 Home Premium
    Service Pack:
    Version : 6.1.7600
    Windows Directory : C:\Windows
    OSLanguage: 1033
    CodeSet: 1252
    CountryCode: 1
    Local: 0409
    Total Physical Memory: 3.99 GB
    Free Physical Memory: 2.50 GB
    Total Virtual Memory: 7.99 GB
    Free Virtual Memory: 3.67 GB
    ***************************** Computer *****************************
    Computer Manufacturer Name: Gigabyte Technology Co., Ltd.
    Computer Model: X38-DQ6
    System Type: x64-based PC
    Computer Name: RAN_JOC
    DomainRole: x2c3419cdc9b8e007
    Number Of Processors: 1
    User Name: Ran_Joc\Jocelyne
    ***************************** Processor ****************************
    Manufacturer: GenuineIntel
    Processor: Intel(R) Core(TM)2 Quad CPU Q9450 @ 2.66GHz
    Description: Intel64 Family 6 Model 23 Stepping 7
    CPU Speed: 2.666GHz
    CPU FSB: 333MHz
    L2 Cache Size: 6.00 KB
    09:55:08: Logical CPUs: 4
    ***************************** Time Zone ****************************
    Time Zone: (UTC-05:00) Eastern Time (US & Canada)
    ****************************** VIDEO *******************************
    Name: ATI Radeon HD 4800 Series
    Processor: ATI display adapter (0x9440)
    Mode: 1920 x 1080 x 4294967296 colors
    Video Ram: 512 MB
    Status: OK
    ****************************** Drives *******************************
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 94.6 GB
    DeviceID: D:
    FileSystem: NTFS
    FreeSpace: 278 GB
    DeviceID: E:
    FileSystem: NTFS
    FreeSpace: 549 GB
    ********************* END OF SYSTEM INFORMATION ********************
    ************************* ProjectMetaData **************************
    <?xml version="1.0" encoding="utf-8"?>
    <SVCD2DVD DateTime="10/6/2010 9:55:09 AM" Filename="NONE">
    <AssetSet>
    <Asset ID="8c0acc03-63ab-482f-9381-bb02c7f5eb68" Path="D:\Azureus\Downloads\The Thin Red Line 1998 Criterion Collection 720p BRRip x264-HDLiTE" Filename="The Thin Red Line.mp4" />
    </AssetSet>
    <DVDStructure>
    <TitleSet Name="The Thin Red Line" PostCmd="" MenuButtonType="0">
    <MenuButton X1="0" Y1="0" X2="307" Y2="46" FontFamily="Tahoma" FontSize="24" FontStyle="3">The Thin Red Line</MenuButton>
    <Title Name="The Thin Red Line.mp4" AssetID="8c0acc03-63ab-482f-9381-bb02c7f5eb68" MplexOffset="0" />
    </TitleSet>
    <DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="D:\BadgerIT\SVCD2DVD v2.5\Backgrounds\B038.jpg" AudioPath="" />
    </DVDStructure>
    <Settings>
    <General InitialAssetFolder="D:\Azureus\Downloads" InitialDVDFolder="E:\Test SVCDtoDVD 1" OutputFolderName="SVCD2DVD_OUTPUT" InitialProjectFolder="D:\Test SVCDtoDVD" InitialMenuBackgroundFolder="D:\BadgerIT\SVCD2DVD v2.5\Backgrounds" DeleteS2DFiles="False" UseDVDShrink="False" />
    <Menu AudioEncoding="Custom_ac3" DefaultCustomAudioPath="" DefaultCustomImagePath="D:\BadgerIT\SVCD2DVD v2.5\Backgrounds\B038.jpg" TVStandard="NTSC" FontFamily="Tahoma" FontSize="24" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="False" EncodeVideo2AudioDuration="False" MenuAspectRatio="AR_16_9" />
    <Process AudioEncoding="ac3" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="True" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" OrderAudioStreams="False" ProcessIfNavPacks="False" />
    <Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" />
    <Burning BurningMethod="NONE" ImgBurnPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" />
    </Settings>
    </SVCD2DVD>
    Processing assets for DVD creation
    =================== AV Details ===================
    File Size: 2.74 GB
    file=D:\\Azureus\\Downloads\\The Thin Red Line 1998 Criterion Collection 720p BRRip x264-HDLiTE\\The Thin Red Line.mp4
    FormatName=mov,mp4,m4a,3gp,3g2,mj2
    Num_Frames=245684
    DurationInSecs=10248
    Duration=02:50:47.1
    VideoCodec=h264
    VideoFFSTNum=0
    Width=1280
    Height=544
    Standard=NTSC (Film)
    BitRate=2304
    AudioStreamCount=1
    Audio1FFSTNum=1
    Audio1StreamID=[0x2]
    Audio1SampleRate=48000
    Audio1Codec=aac
    Audio1BitRate=0
    Audio1Channels=6
    AVI2MPG: 3088kbs Full-D1
    Pass 1/1: Processing The Thin Red Line.mp4
    [The Thin Red Line] 09:55:09: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
    [The Thin Red Line] 09:55:09: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
    [The Thin Red Line] 09:55:09: libavutil 49.12. 0 / 49.12. 0
    [The Thin Red Line] 09:55:09: libavcodec 52. 6. 0 / 52. 6. 0
    [The Thin Red Line] 09:55:09: libavformat 52.23. 1 / 52.23. 1
    [The Thin Red Line] 09:55:09: libavdevice 52. 1. 0 / 52. 1. 0
    [The Thin Red Line] 09:55:09: libswscale 0. 6. 1 / 0. 6. 1
    [The Thin Red Line] 09:55:09: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
    [The Thin Red Line] 09:55:09: [mov,mp4,m4a,3gp,3g2,mj2 @ 0x10ac700]edit list not starting at 0, a/v desync might occur, patch welcome
    [The Thin Red Line] 09:55:09: Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'D:\Azureus\Downloads\The Thin Red Line 1998 Criterion Collection 720p BRRip x264-HDLiTE\The Thin Red Line.mp4':
    [The Thin Red Line] 09:55:09: Duration: 02:50:47.12, start: 0.000000, bitrate: 2304 kb/s
    [The Thin Red Line] 09:55:09: Stream #0.0(und): Video: h264, yuv420p, 1280x544, 23.98 tb(r)
    [The Thin Red Line] 09:55:09: Stream #0.1(eng): Audio: aac, 48000 Hz, 5.1, s16
    [The Thin Red Line] 09:55:09: Output #0, dvd, to 'D:\Azureus\Downloads\The Thin Red Line 1998 Criterion Collection 720p BRRip x264-HDLiTE\The Thin Red Line_S2D.mpg':
    [The Thin Red Line] 09:55:09: Stream #0.0(und): Video: mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=1-31, 3088 kb/s, 23.98 tb(c)
    [The Thin Red Line] 09:55:09: Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [The Thin Red Line] 09:55:09: Stream mapping:
    [The Thin Red Line] 09:55:09: Stream #0.0 -> #0.0
    [The Thin Red Line] 09:55:09: Stream #0.1 -> #0.1
    [The Thin Red Line] 09:55:09: Press [q] to stop encoding
    [The Thin Red Line] 09:55:09: [h264 @ 0x175c720]Cannot parallelize deblocking type 1, decoding such frames in sequential order
    [The Thin Red Line] 09:55:09: Error while decoding stream #0.1
    The above line repeats itself
    Here is the part that follows the above mentioned line
    [The Thin Red Line] 10:31:20: Error while decoding stream #0.1
    10:32:13: Adding subtitle stream
    10:32:14: SupMuxer: Done.
    10:32:14: Done: Processing assets for DVD creation
    Authoring DVD Folders
    10:32:14: Creating TitleSet # 1
    10:32:14: SVCD2DVD: DVDfolders
    Generating DVD folders please wait....
    10:32:14: -->: DVDFolders creating VTS
    10:32:14: -->: VTS 01
    10:32:14:
    DVD Folders: Processing D:\Azureus\Downloads\The Thin Red Line 1998 Criterion Collection 720p BRRip x264-HDLiTE\The Thin Red Line_S2D.mpg...
    10:32:14:
    It is at this point I get the error message mentioned in the 1st post.
  5. Chrissy, did you see any problem from this log file. I had tried it with Convert X and had no problem converting this file. But, my software of preference is yours.
  6. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Looks like the audio was causing an issue (Stream 0.1).... i have a newer build you can try if you like on the file in question.
  7. I do not mind testing a new file if you wish to see if it soves the problem. As I had mentioned this is the software of my choice and it was the one ond only time that this had happened to me.
    Regards
