I am trying to encode a video to x264 via CLI in the command prompt and am having trouble, mainly with the input commands.
So far I have
x264 -o C:\Users\Videos\ys 2 trailer.avs --output C:\Users\Videos\Ys_2_Trailer.mkv --crf 1 --profile high --preset veryslow
I received the errors:
ffms [error]: could not create index
lavf [error]: could not open input file
raw [error]: raw input requires a resolution.
x264 [error]: could not open input file `2' via any method!
What am I typing incorrectly?
Results 1 to 10 of 10
Put quotes around filenames with spaces.
x264 -o "C:\Users\Videos\ys 2 trailer.avs" --output C:\Users\Videos\Ys_2_Trailer.mkv --crf 1 --profile high --preset veryslow
CRF 1? You're gonna get a very big file. -
... Also this is the syntax for x264:-
So you need to rearrange the command, though you probably have other problems too.x264 [options] -o outfile infile
Helpfile is attached.Last edited by bat999; 6th Oct 2010 at 12:20.
Actually, the options can be in any order. But I noticed another error, get rid of the -o:
x264 "C:\Users\Videos\ys 2 trailer.avs" --output C:\Users\Videos\Ys_2_Trailer.mkv --crf 1 --profile high --preset veryslow
I'm assuming here that "C:\Users\Videos\ys 2 trailer.avs" is the source AviSynth script. -
x264 --pass 2 --bitrate 1800 --stats "C:\Users\Videos\Ed Eddn eddy Episode 1.stats"
--output "C:\Users\Videos\Ed Edd n Eddy Episode 1.mkv" "C:\Users\Videos\Ed Edd n Eddy Episode 1.avs"
avs [error]: failed to load avisynth
x264 [error]: could not open input file `C:\Users\Videos\Ed Edd n Eddy Episode 1.avs'
What is the problem? -
Could try using the experimental build of Virtualdub
http://www.virtualdub.org/beta/VirtualDub-1.9.X-test30.zip
With external encoder to create x264 mkv.
Here is a guide to setup and use the encoder sets.
http://forums.virtualdub.org/index.php?act=ST&f=3&t=18840& -
x264 --fullhelp 1>fullhelp.txt
also see
http://mewiki.project357.com/wiki/X264_Settings -
Multiavchd:override presets by using custom x264 cli
By lutinor in forum Newbie / General discussionsReplies: 0Last Post: 4th May 2011, 03:53 -
x264 CLI
By zammil in forum Video ConversionReplies: 16Last Post: 22nd Jan 2011, 12:22 -
Replace x264 Encoder with a "CUDA" CLI app?
By Raycaster in forum Blu-ray RippingReplies: 3Last Post: 31st Dec 2010, 04:03 -
Need help with .vob's + x264 cli
By Frost746 in forum Newbie / General discussionsReplies: 2Last Post: 20th Jul 2010, 22:14 -
Alternate method for importing x264 cli encoded videos for.. [RESOLVED]
By vhelp in forum Video ConversionReplies: 7Last Post: 23rd Dec 2008, 21:30
