Hi!
I use webinars service in the internet and they save webinars in adobe air file format. And after that I dowloading webinar record and simply install it onto my workstation (MS Windows Vista sp2). My due is to convert from flv-format to mp3 so i could publish it on a website.
Recently I found that my ffmpeg.exe when it converts flv file to mp3 format it runs out with error (see below).
Earlier everything was OK. but now I got a problem.
Could anybody tell me what's the matter of this mistake?
any help would be
Code:c:\>ffmpeg -i stream.flv -ar 22050 -sameq stream.mp3 FFmpeg version 0.5, Copyright (c) 2000-2009 Fabrice Bellard, et al. configuration: --enable-gpl --enable-postproc --enable-swscale --enable-avfilter --enable-avfilter-lavf --enable-pthreads --enable-avisynth --enable-libfaac --enable-libfaad --enab le-libmp3lame --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libxvid --enable-libx264 --enable-memalign-hack libavutil 49.15. 0 / 49.15. 0 libavcodec 52.20. 0 / 52.20. 0 libavformat 52.31. 0 / 52.31. 0 libavdevice 52. 1. 0 / 52. 1. 0 libavfilter 0. 4. 0 / 0. 4. 0 libswscale 0. 7. 1 / 0. 7. 1 libpostproc 51. 2. 0 / 51. 2. 0 built on Mar 16 2009 16:09:18, gcc: 4.2.4 [Sherpya] Input #0, flv, from 'stream.flv': Duration: 01:37:24.56, start: 0.000000, bitrate: N/A Stream #0.0: Video: 0x0000, 1k tbr, 1k tbn, 1k tbc Stream #0.1: Audio: nellymoser, 11025 Hz, mono, s16 Output #0, mp3, to 'stream.mp3': Stream #0.0: Audio: libmp3lame, 22050 Hz, mono, s16, 64 kb/s Stream mapping: Stream #0.1 -> #0.0 Press [q] to stop encoding [libmp3lame @ 0x2ef8c50]lame: output buffer too small (buffer index: 9404, free bytes: 388) Audio encoding failed
I would try another ffmpeg build, see http://ffmpeg.arrozcru.org/autobuilds/
Or check http://www.experts-exchange.com/OS/Linux/A_2592-Fixing-output-buffer-too-small-issue-f...ibmp3lame.html -
Ok. this decision was useful for some flv files, but some of them are still convert with mistakes, such as:
Code:D:\ffmpeg-latest-mingw32-static\bin>ffmpeg.exe -i "VILAVI WEB-Club 20100927.flv" "VILAVI WEB-Club 20100927.mp3">> res.txt FFmpeg version SVN-r25366, Copyright (c) 2000-2010 the FFmpeg developers built on Oct 6 2010 04:13:18 with gcc 4.4.2 configuration: --enable-gpl --enable-version3 --enable-libgsm --enable-pthreads --enable-libvorbis --enable-libtheora --enable-libspeex --enable-libmp3lame --enable-libopenjpeg --e nable-libschroedinger --enable-libopencore_amrwb --enable-libopencore_amrnb --enable-libvpx --arch=x86 --enable-runtime-cpudetect --enable-libxvid --enable-libx264 --extra-libs='-lx2 64 -lpthread' --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --target-os=mingw32 --enable-avisynth --cross-prefix=i686-mingw32- --cc='ccache i686-mingw32-gcc' --e nable-memalign-hack libavutil 50.32. 2 / 50.32. 2 libavcore 0. 9. 1 / 0. 9. 1 libavcodec 52.92. 0 / 52.92. 0 libavformat 52.79. 0 / 52.79. 0 libavdevice 52. 2. 2 / 52. 2. 2 libavfilter 1.48. 0 / 1.48. 0 libswscale 0.12. 0 / 0.12. 0 [flv @ 0026c0b0] Estimating duration from bitrate, this may be inaccurate Input #0, flv, from 'VILAVI WEB-Club 20100927.flv': Metadata: duration : 5845 creationdate : Mon Sep 27 11:28:51 Duration: 01:37:24.56, start: 0.000000, bitrate: N/A Stream #0.0: Video: [0][0][0][0] / 0x0000, 1k tbr, 1k tbn, 1k tbc Stream #0.1: Audio: nellymoser, 11025 Hz, mono, s16 File 'VILAVI WEB-Club 20100927.mp3' already exists. Overwrite ? [y/N] y Output #0, mp3, to 'VILAVI WEB-Club 20100927.mp3': Metadata: TSSE : Lavf52.79.0 Stream #0.0: Audio: libmp3lame, 11025 Hz, mono, s16, 64 kb/s Stream mapping: Stream #0.1 -> #0.0 Press [q] to stop encoding [nellymoser @ 0026d8f0] Tag size 20. 64.0kbits/s Last message repeated 784 times= 64.0kbits/s [nellymoser @ 0026d8f0] Tag size 116. [nellymoser @ 0026d8f0] Tag size 211. Last message repeated 12 timese= 64.0kbits/s [nellymoser @ 0026d8f0] Tag size 20. Last message repeated 9 times [nellymoser @ 0026d8f0] Tag size 211. Last message repeated 33 times [nellymoser @ 0026d8f0] Tag size 20. Last message repeated 45 times [nellymoser @ 0026d8f0] Tag size 211. Last message repeated 20 times [nellymoser @ 0026d8f0] Tag size 116. [nellymoser @ 0026d8f0] Tag size 20. Last message repeated 6 times [nellymoser @ 0026d8f0] Tag size 211. Last message repeated 10 times [nellymoser @ 0026d8f0] Tag size 116. Last message repeated 1 times [nellymoser @ 0026d8f0] Tag size 211. Last message repeated 43 timese= 64.0kbits/s [nellymoser @ 0026d8f0] Tag size 116. [nellymoser @ 0026d8f0] Tag size 20. Last message repeated 1 times [nellymoser @ 0026d8f0] Tag size 211. Last message repeated 17 times [nellymoser @ 0026d8f0] Tag size 20. Last messa Last message repgee atrepeaetedd 1 tim e1 stimes size= 958kB time=122.57 bitrate= 64.0kbits/s video:0kB audio:958kB global headers:0kB muxing overhead 0.003366% Received signal 2: terminating.
Code:"[nellymoser @ 0026d8f0] Tag size 20. 64.0kbits/s Last message repeated 784 times= 64.0kbits/s [nellymoser @ 0026d8f0] Tag size 116. [nellymoser @ 0026d8f0] Tag size 211. Last message repeated 12 timese= 64.0kbits/s [nellymoser @ 0026d8f0] Tag size 20. Last message repeated 9 times"
FFMPEG AVI to FLV Converting Help!
By sp0oon in forum Video ConversionReplies: 6Last Post: 20th Jan 2010, 11:48 -
ffmpeg | How can i get the best quality / filezise ratio converting to FLV
By landuchi in forum Video ConversionReplies: 2Last Post: 26th Oct 2009, 13:33 -
Trouble converting AVI(divx)+MP3 to FLV+MP3
By BLboy in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 04:36 -
Problem converting mov to flv with ffmpeg
By zigune in forum Video ConversionReplies: 8Last Post: 15th Jul 2009, 02:03 -
Mux a FLV AVI + MP3 -> FLV with ffmpeg or mencoder?
By Colmino in forum Video ConversionReplies: 9Last Post: 29th Mar 2008, 22:11
