  1. Hi,
    I am experiencing a problem in Blu ray backup on Verbatim BD-R (LTH Type) discs using Imgburn 2.5.2.0 on my LG GGW H20L writer.I am getting the error as shown in the attachment.
    Please help.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    What program did you use to decrypt the original Blu Ray disc?
  3. I downloaded the file as a true hd
  4. Hi,
    The error is as follows
    I/O ERROR
    Device:[2:0:0]HL-DT-ST-BD-RE GGW-H20L YLO2 (E(ATA)
    ScsiStatus:0x02
    Interpretation:Check Condition
    CDB:AA 00 00 00 00 20 00 00 00 20 40 00
    Interpretation: Write(12)- Sectors: 32 - 63
    Sense Area:71 00 03 00 00 00 00 0A 37 2D 03 B4 0C 00 00 00 00 00
    Interpretation: Write Error
    Please help
  5. Member ricoman's Avatar
    Jun 2004
    CT, USA
    As it says, you have a Write Error. Have you updated to the latest firmware. It's my understanding that this drive had a problem with LTH media until it got a firmware update. LTH media is a problem for some bluray burners. I won't buy it until I know it has a better track record.
    I love children, girl children... about 16-40
    W.C. Fields
  6. Thanks a lot for the comments. Yes, it wa s a firmware update that solved the issue. But then there is another issue of a different nature.The blurays that I have burnt have two folders namely BDMV & Certificate. But please advise as to how to burn a .ts file.Is there anyway to have the menus and the whole thing with this type of file format.
    Thanks again
  7. Member yoda313's Avatar
    Jun 2004
    The Animus
    You can use tsmuxer to make a bluray structure from the ts file.
    Edit - you can also use multiavchd to make a bluray structure from the ts file as well.
    If the ts file isn't in bluray specs than some reencoding may be necessary.
    You can do menus with multiavchd - I don't believe there are any menu options from tsmuxer - just movie only.
  8. Member ricoman's Avatar
    Jun 2004
    CT, USA
    Whatever you use, make sure you drag both the BDMV & Certificate files together, they must go together or you will end up with a bunch of video files that will not be linked in a continuous movie, each file will be separate.
    W.C. Fields
