I need a media center that i can hook up to my hdtv (with hdmi) and be able to set the audio to go through optical audio instead of hdmi when i want to. I would like it to either have the capability to have an internal hdd or use esata. It would also be great if i could stream movies from the media center to other devices like a ps3. I dont want to go over $200 thanks for the help.
Have you considered a Western Digital WDTV Live? It would do most all of that for about $100. Throw in an external hard drive and you should be set.
And welcome to our forums.
thanks for the reply. Yea i have been looking at that one but i really want/need either esata or the ability to put a hard drive in the system.
USB 2.0 is plenty fast enough for HDD MKV playback. But you could get a external enclosure with eSATA/USB 2.0 and use the eSATA to load the videos. I may be wrong, but I don't know of any standalone external boxes that also have eSATA and work similar to a WDTV.
Or you could build a HTPC that would do all that, but not likely for ~$200US.
What I do is use video servers to hold my videos. These are recycled computers with multiple hard drives, accessed over a LAN connection to the WDTV or to my other computers for playback. -
OK that sounds great! Will i be able to stream movies from my usb hard drive to other devices like a ps3? If so, do you know if i can stream a movie to a ps3 and watch a movie on the wdtv at the same time? What do you think of the AC Ryan PLayonHD? or the Dragontech iobox-100HD?
any good "my movies" plugins for Windows media Center?
By craig198 in forum Media Center PC / MediaCentersReplies: 0Last Post: 26th Jan 2011, 13:47 -
Need Help Finding a good Camcorder
By PyroMan99 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 30th Nov 2010, 15:23 -
Desperately Need Help Finding a Good DVD Player With a Usb Port That Has...
By thewonderer in forum DVD & Blu-ray PlayersReplies: 11Last Post: 9th Apr 2009, 16:07 -
Looking for a good Media Center Program with Remote....
By remission in forum Newbie / General discussionsReplies: 1Last Post: 8th Apr 2009, 13:09 -
Sharing TV - 1 Vista Media Center Server to Vista Media Center PC
By JBredensteiner in forum Media Center PC / MediaCentersReplies: 8Last Post: 14th Jul 2007, 01:33
