I'm planning to do some SD captures from cable TV (box analog out) to author DVDs. I can either-
1. Capture and encode with Pioneer DVD recorder then author.
2. Capture and encode with a Hauppage PVR-250 card then author.
3. Capture to AVI / MJPEG / etc. with a standard PCI TV card, then convert to MPEG with software, then author.
In the end, I'm not sure there will be too much difference in the final products, but I was wondering if anyone had any comments or recommendations.
Results 1 to 1 of 1
Video8/Hi8 playback/capture options
By HDClown in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 21st Dec 2025, 05:00 -
Opinion between two VHS capture options
By Spektre in forum Capturing and VCRReplies: 8Last Post: 16th Jun 2011, 11:50 -
Help Choosing Capture/Tuner Card...or Other wise
By drtalk in forum Capturing and VCRReplies: 2Last Post: 3rd Sep 2010, 18:46 -
Low profile capture card options
By GLE3 in forum Capturing and VCRReplies: 7Last Post: 30th Mar 2010, 18:59 -
need advice on choosing a capture card
By specane in forum Capturing and VCRReplies: 3Last Post: 18th Jun 2007, 11:28
