Hi all,
First, pardon me if the question was answered before. If so, I couldn't find it. Second, I'm a noob.
As subject says, I'm trying to convert MP4/AAC to XVid/AC3 6ch so I can play it on my standalone DVD player. Whatever I try, video comes out fine, but audio doesn't. Converting to MP3 2ch audio works like a charm, but I really want 6 channels.
I've tried with FormatFactory first. VLC (Codec Info) shows that correct audio stream is preset, but I can't hear any sound, neither on computer or standalone player. Then I've read somewhere that FF has problems with encoding AC3, so I've uninstalled it and tried with other programs.
Whatever I tried (SUPER, XVid4PSP, ...) the same problem remains (some other too, but they don't support MP4). I've also tried to reinstall codecs (K-Lite and AC3filter), but no change.
I'm almost sure that this has something to do with my computer, but I'm really not competent enough to figure out what.
Does anyone have a suggestion for me? Thank you in advance!
/b
Results 1 to 17 of 17
- Simple advice please do not try to convert AAC (2ch or 6 ch) to AC3 (6ch), why?
AAC follows different channel mixing algorithm than AC3, so even you are successful to convert it to AC3 (6ch), it sounds crappy.
Albeit AAC (6ch) can be used to fake AC3 (6ch), but pro-listener can easily find the difference.
- All the softwares as far as I know, they can Downmix AC3 perfectly.
For AC3 - 6 channels Original Source bearing AC3 6 channels or DTS is highly recommended.
- Nothing much to with computer settings. As said before, Original Source bearing AC3 6 channels or DTS is highly recommended coz original channels are recoded through professional channel mixers. No software can give you that SoundLab effect.
May be. AAC (2ch or 6 ch) ---> AC3 (2ch) may go good, any many softwares probably convert it without problem.
Somehow, it is solely my personal experience. i like mp3 (2 ch lame 3.98.4) in stand-alone DVD/DiVx Player -
This will be little complicated. even though you succeeded to creating aac to ac3, the result will be wrong channel order in final out put file.
Try the below method it may work for you.
use nero wave editor (ultra 7 version) to convert 5.1 aac to 5.1ac3. then mux with mp4muxer. you will get mp4 with ac3 5.1
then convert to xvid. you will get xvid with ac3 5.1. -
hi guns1inger;
1) Are you taking about mp4-->ac3 6 ch. through avstodvd?
-or-
2) mp3 2ch--->ac3 6ch through avstodvd? (i guess most of the DVD Authroing Tools will be able to convert mp3-->ac3 6 ch.)
Have you tried either 1) or 2) by yourself? How was the result?
I will trying to evaluate AVStoDVD on my friends machine having Windows as OS. -
[QUOTE=_MrC_;2023266] _MrC_
AVStoDVD Author
First of all, Thanks for your nice 'n' free tool, and...
thanks for the response too.
I have figured out what i missed in dvd menu is to click the menu tab. basic dvd-menu is satisfactory (need little more cosmetics).
I wonder how avi (XViD + AC3 2ch) will be rendered?
Will it be rendered as vob + ac3 2ch or it would be possible to upmix to vob + ac3 5.1 ch using AVStoDVD?
While the title of this thread is MP4/AAC -> XVid/AC3 6ch.
I would prefer MP4/AAC -> XVid/AC3 2ch coz while playing DVD Dolby (AC3) 2 channel in home theatre system.
Hardware decoder is able to upmix 2 ch into 5.1 or 7.1 ch perfectly.
As DVD (dolby 2ch) sounds great, and anyone still having strong preference for 5.1ch,
it would be better to capture the video.. -
AVStoDVD cannot do channels upmix.
If you leave default preferences, then the AC3 track will be demuxed and kept as it is in the final DVD. Instead if you choose to re-encode audio, then channels options will be 1.0 and 2.0.
In the latter case, remember to properly setup your directshow audio filter mixer (it could be AC3Filter of ffdshow, if ffdshow then AVStoDVD will take care to adjust it automatically).
Bye -
This being quite an old thread, some things must have changed during these last 4 years?
I use avidemux to convert my movies from 6ch AAC (MP4, AVC+AAC) to 6ch AC3 (MKV, AVC+AC3).
My Logitech Z-5450 detects the AC3 as DTS whereas the AAC is detected as stereo (or alternatively upmixed using ProLogic II)
If someone could explain more as to how avidemux manages to convert the sound, how the channels differ or what channel is rendered "wrong", or why the AC3 "sounds crappy", or why differences "would easily be detected by a pro" I would be very thankful
some additional info:
I used mediainfo to confirm the audiostreams both before and after the conversion.
Both file extensions are .mp4.
In avidemux i use the presets "copy" for video and "AC3 (lav)" for audio. I havent tried AC3 (aften) and do not know the difference between the two. -
I use AVIDemux mostly for editing, not conversions. Not sure about your source, but I prefer VidCoder for video>MKV(H.264) with AC3 encodes. I convert all my video files to AC3 (Usually surround sound) and use H.264 for most all my video encodes. Even my BD player seems to be ok with this format.
We probably have some AVIDemux experts here that can answer your other questions.
*Really, if you have a new topic, best to start a new thread. You can link to older threads as you like, but we discourage adding on to very old threads with new questions as it makes it harder for other members searching for 'up to date' answers for a topic.
And welcome to our forums.
Moderator redwudz
MP4+AAC 6ch streaming using PS3 Media Server
By faissalfilho in forum Video Streaming DownloadingReplies: 1Last Post: 6th Jun 2011, 06:12 -
Converting MKV with 6ch AAC to AVI/MP4?
By Startropic1 in forum Video ConversionReplies: 1Last Post: 7th Nov 2010, 10:26 -
Convert AAC 6ch to AAC 2ch w/ Dolby Pro Logic II Surround info
By SiegeX in forum AudioReplies: 5Last Post: 28th Dec 2009, 17:58 -
MKV to MP4 for PS3 with dual-audio (2ch AAC + 6ch AC3)
By sexyclient in forum Media Center PC / MediaCentersReplies: 0Last Post: 7th Dec 2008, 23:01 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19
