I used ChrisTV about 2 years ago, as it's the only one that allowed me to adjust the recording parameters properly. I'm running a PC on Windows 7 now, and regardless of my settings, it captures in 720x480 @ ~7000kbps bitrate.
Is there any decent customizable software I can use?
Results 1 to 10 of 10
Been a long time since I saw you.
Your email started bouncing a couple of years ago!
Did this ATI card not come with ATI software?Want my help? Ask here! (not via PM!)
haha- yeah.. cazeek@optonline.net should still work- I actually get some of your tv ps e-mails still.. finally getting back into this. How's everything?
Think it came w/ some cyberlink garbage, but nothing on the disc is compatible w/ Windows 7. When I first got the card, I had an AIW card previously installed on the computer, so I still had ATI MMC which worked pretty well. I actually solved this problem after literally about 8 hours of on and off, suicidally frustrating efforts. I uninstalled everything, downloaded the 64-bit Windows XP driver instead of Vista 64bit, and it worked.. had tried the 750 model's new drivers, and everything else I could think of, but for right now this is working.
So, solution if anyone refers to this: Use the Theater 550 Pro driver Windows XP 64-bit version, with ChrisTV.
Quality is actually great, but that's mostly due to the hardware I'm sure, so would still love a suggestion for a better third party capture software that can handle the card. -
What kind of features are you looking for in the software? Are you looking for a full-fledged media center or something more basic? Do you want to initiate recordings from a program guide, do timer-based recordings, or do manual captures? Also, which settings do you want to be able to adjust for the card itself?
Don't need any of the media center type stuff. I want to be able to do a manual recording with full control over Video/Audio Bit-Rate, Audio Frequency, Video Resolution, etc. Those are the bare minimum, and extras are a plus.
http://www.kiva.org/about -
Was afraid that was the response.. I love the quality of the card though- crazy that there's no software out there to control it
OK, you got my attention with that one!
So, how did you get the WDM drivers to work on a Windows 7 64bit system? Did you install it in "XP compatible mode" according to one SP or another? Prey tell! Just so you know, I just picked up a ChrisTV Pro license. It does seem to support the Theater 550 Pro well, but if there's a chance to get it to work on my W7 box I'll retire the old XP box (well, I'll repurpose it but you know what I mean.)
Thanks in advance, and thanks for the tip! -
If I remember correctly, all I did was completely uninstall the drivers and install the Windows XP 64 bit drivers on my Windows 7 machine (instead of the Windows 7 or whatever they offer). Hope that helps
ATI Theatre Pro 550
By didikai in forum Capturing and VCRReplies: 2Last Post: 27th Feb 2012, 11:15 -
Theater Pro 550
By Jenkjunk in forum Capturing and VCRReplies: 4Last Post: 12th Oct 2009, 21:48 -
Mainstream S/W to take full advantage of ATI 550 PRO H/W encoding
By inspiron2 in forum Capturing and VCRReplies: 2Last Post: 6th Jul 2008, 17:24 -
Any Video Capture Software for ATI Theater 550Pro?
By quantass in forum Capturing and VCRReplies: 1Last Post: 8th Sep 2007, 18:26 -
Ati 550 pro best capture software...
By RE*S.T.A.R.S.*2 in forum Capturing and VCRReplies: 13Last Post: 14th Jun 2007, 17:46
