When I look for my Twixtor for CS4 when I search for effects it is not there when I clearly installed it and entered my serial key. Any ideas how to fix it or where it might be? Thanks for your help.
It will be under RevisionFX. Look under effects => "R" ; not "T" for twixtor
it doesn't show up I installed it to just my C:/ drive so I don't know if it should be someplace else...?
install it to the after effects plugins folder, and should show up
or the adobe\common\plug-ins\CS4\MediaCore -
It appears. I didn't know the automatic installation directory was just to your C drive. I should have known After Effects wouldn't have found it in C. Thanks a bunch.
After Effects and Twixtor Issue
By Squid_uk in forum EditingReplies: 2Last Post: 30th Nov 2011, 13:55 -
Cant find or see my media cache on After Effects CS4
By afrojavi in forum EditingReplies: 0Last Post: 5th Jul 2010, 19:07 -
Changes in Adobe Premiere CS4 not reflected in Encore CS4 Timeline
By Funky Monk in forum Authoring (DVD)Replies: 0Last Post: 23rd Oct 2009, 07:51 -
Adobe Media Encoder CS4 resizing
By dedek74 in forum Video ConversionReplies: 4Last Post: 22nd Aug 2009, 15:37 -
Problem with masking in after effects cs4
By Morten in forum EditingReplies: 6Last Post: 16th Aug 2009, 08:52
