Hi.
I just got the BD 390 and have so far had a few probs.
The most recent is that I am trying to play a few episodes of a TV series. The files are MKV x264 and I can play all of them on my PC.
But the LG skips over a few files (i.e episodes). Or to be correct, it plays a few seconds of the files and than skips to the next, like it thinks that the file is just a few seconds long.
No error message or anything.
What can this be?
(Lates firmware loaded)
Thanks!
The 390 is coming onto 2 years old...old in Blu Ray player terms. Have you tried the files on the newer LG players like the 560, 570 or 590? MKV playback is spotty at best and you are at the mercy of the original encoder. Usually, a skip means the file is broken. This can be caused by CRC errors (file mismatch), missing bytes, missing frames, etc. I don't have an LG, so I can't check but you might go and have a look at the LG site to find out what the latest firmware fixed (or broke). You might also want to check the owners group at avsforums. Good luck....
Joining .VOB files to avoid skips
By logika in forum EditingReplies: 2Last Post: 27th Nov 2011, 15:28 -
Have a Sanyo DWM 390 dvd player that shows only black and white
By blackkat in forum DVD & Blu-ray PlayersReplies: 21Last Post: 28th Jan 2011, 20:24 -
Incorporate a light weight browser in an LG BD-390
By wschomburg in forum Video Streaming DownloadingReplies: 1Last Post: 12th Dec 2010, 22:17 -
Samsung P-390 USB drive
By morritz in forum Newbie / General discussionsReplies: 1Last Post: 13th Mar 2010, 07:15 -
LG BD 390 Network Connection Issues Solved
By Norag in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jan 2010, 00:01
