  1. Anyway, the movie I'm trying to convert to SVCD (it's a DivX file) is the 2 cd version of Goonies ala sharereactor.
    TMPGEnc wont' recognize the audio, neither will VirtualDub, Windows Media Player will play it but can't tell me what the codec is so I can encode it. Notably, WinAMP won't play the audio file I simply extract (without converting) with Virtual Dub.
    Any ideas?
    Thanks in advance,
    Medieval
  2. Here's an off-the-wall thought.
    If Media Player will play it, Avisynth might be able to frameserve it to VirtualDub or TEMPGne for encoding to whatever format you want to save it in.
    I say this without ever having tried it. Would be interested to know if it works. Good luck!
  3. Is there a guide on how I could do this?
  4. I figured it out.
    Didn't work.. when I frameserv it with Avisynth it still doens't recognize the audio at all.
    Maybe if I try to get all possible audio codecs, one of 'em might be it.
    Isn't it strange that the codec is unrecognizable? Or is this normal?
